Is your rig due for replacement of the stale air in the tires with fresh air? I've let mine go over three weeks already. .. I'd better get off my azz and just do it.
Now I am feeling guilty about not checking my headlight fluid after I got done changing out my alternator earlier today. Geez, guess I better go and see if it needs topping off.
One last one Gangster: Cylinder Head Caulk.
My 240 never had any power until I discovered this stuff. Goes like this:
Pull the cylinder head(s), remove head gasket, toss. Get a tube of cylinder head caulk and put a bead around all the holes, especially the six or eight big ones. Re-install heads without gasket.
Increases compression, runs like a champ, much more power.
