Condenser patch
Old Jul 8, 2003 | 10:19 PM
Teroy's Avatar
Teroy
Condenser patch
Anybody ever tried JB welding a hole in the "U" pipes on the end of a condenser???
Old Jul 8, 2003 | 11:01 PM
greg_23805's Avatar
greg_23805
Condenser patch
I wouldn't use jbweld. Go to an AC supply house like Johnson Supply or United Refrigeration and get an epoxy made for patching high temp metals. Don't hold out much hope that this will work, I've tried epoxy before on condensors to no avail but it's always worth a try. Sand down the area a little first to give the epoxy something to grab on to and don't press the epoxy into the hole or you will get it inside the system. Make sure you let it cure for the max time because you know what happens otherwise.
Old Jul 8, 2003 | 11:30 PM
Teroy's Avatar
Teroy
Condenser patch
Thx for the advice greg.
Any ideas what one would cost out of a junkyard? and what years will work in my truck?
Old Jul 8, 2003 | 11:31 PM
greg_23805's Avatar
greg_23805
Condenser patch
no idea but I'm guessing a new condensor would be a couple hundred bucks at least. Try the junk yard first
Old Jul 9, 2003 | 08:27 AM
oldfordtrucksrule's Avatar
oldfordtrucksrule
Condenser patch
try the local radiator shop. they can fix em.
Tknight85
Sep 27, 2011 07:42 PM
bigwillie23
Nov 6, 2006 05:22 PM
blueford
May 29, 2006 07:54 PM
Leland
1978 - 1996 Big Bronco
22
Mar 23, 2002 09:06 PM
