Condensation in Headlight
Old Nov 6, 2006 | 07:01 AM
bigwillie23's Avatar
bigwillie23
There's a lot of condensation in my driver's side headlight casing, but not the passenger side one. Does anyone know if the headlight unit can be removed to clear up the condensation, or is this going to be a permanent condition?
Old Nov 6, 2006 | 01:45 PM
Swordfishfur's Avatar
Swordfishfur
You can remove the housing. Look in your aowners manual under headlight replacement. There are two tabs you pull up to release the housing, then you CAREFULLY remove the bulb and you'll have the light housing in your hands. Good luck drying and sealing it.
Old Nov 6, 2006 | 05:22 PM
aagitch's Avatar
aagitch
You can remove the entire headlamp assy but you will have very limited access to the inside of the casing and lens. My driver's side is the same way but not the passenger. After I looked real close, the lens has two small holes in it. Looks like from a drill. Passenger side doesn't. Don't know if the previous owner did it. When washing the vehicle I had been accidentally spraying water in the little holes which has caused the condensation. Also one of the rubber pieces on the back of the lense was missing. I'll probably just get a new assy.
JoSHN
2004 - 2008 F150
Nov 27, 2011 10:35 PM
mantta
Sep 2, 2009 09:56 PM
SPreston2001
Jul 6, 2008 11:04 PM
sclarkjohn
1983 - 2012 Ranger & B-Series
Jan 12, 2004 11:59 PM
ktsr
May 22, 2003 09:59 AM
