Clutch Problems
Old Jul 8, 2003 | 09:56 PM
mrwillie66's Avatar
mrwillie66
Clutch Problems
Just spent the entire day on replacing the clutch in my 66. It has a 352 with three on the tree. My problem is that the pedal will only return only half way once depressed. I've made all the adjustments I know to make but to no avail. Anybody have any ideas?
Thanks, mrwillie66
Old Jul 8, 2003 | 10:54 PM
juchert1's Avatar
juchert1
Clutch Problems
does the clutch engage in and out if not the throw out bearing may be caught up
juchert1
Old Jul 8, 2003 | 11:36 PM
mrwillie66's Avatar
mrwillie66
Clutch Problems
Sometimes. We've done just about everything to try to fix it. Plan on pulling the whole thing out and backtracking tomorrow. I should have just swapped it out with a fmx that I have but it's more fun to shift the gears!!
Old Jul 8, 2003 | 11:45 PM
johnsalterego's Avatar
johnsalterego
Clutch Problems
I'll have to admit to installing the friction disk backwards one time - it's not all that hard to do if you are in a hurry. The center piece hits the flywheel making the whole thing too thick, so the pressure plate doesn't fully release. The end result was a low pedal and no neutral... and no one to blame but myself!
Old Jul 9, 2003 | 06:04 PM
juchert1's Avatar
juchert1
Clutch Problems
than the only thing you can do is take the tranny back out the t.b most likly popped off
juchert1
mrwillie66
May 7, 2005 01:16 PM
mrwillie66
Feb 7, 2005 07:05 AM
mrwillie66
Jan 24, 2005 08:53 PM
mrwillie66
Dec 15, 2004 06:52 AM
