How long should it......
Old Jun 19, 2014 | 10:15 PM
Restlesswildman's Avatar
Restlesswildman
Take to replace an injector the first time doing it? #5 tossed a code this past week and I am debating doing it myself, but am thinking it might be more then I want to screw with.
I am a fair wrench, just not sure I want to mess with this.
Old Jun 19, 2014 | 10:17 PM
78fordman's Avatar
78fordman
4 hrs. It's not bad. The 2 bottom oil rail bolts near the air box will be the biggest pain.
Sent from my leash using IB AutoGroup
Old Jun 19, 2014 | 10:20 PM
Restlesswildman
Thanks for the replay.....
is there anything else I need to know before I dig into this?
Old Jun 19, 2014 | 11:09 PM
9228.bobcat's Avatar
9228.bobcat
Not really. Its not a big job. Might grab a 12mm ratchet wrench for the two bolts on the bottom of the valve cover by the air box.
Old Jun 19, 2014 | 11:50 PM
Yahiko's Avatar
Yahiko
Don't forget the right set of long Torx bits.
Sean
Old Jun 19, 2014 | 11:57 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
T40 long is the most important.
A 12mm flex ratchet is nice for the valve cover bolts but not a deal breaker.
The oil rail bolts are a pain near the air box without a mini-ratchet wrench.
First timer on the passenger side, 4 hours sounds fair.
Josh
Old Jun 20, 2014 | 09:56 AM
John Irwin's Avatar
John Irwin
I'm a dumb farmer, and I've done it a few times. 12mm ratchet wrench... your back and guts will thank you later. When I did mine, I went so far as to buy a new torque wrench with a lower scale so it would be more accurate than the one I had. Be sure the injector hole is clean, and that the copper washer comes out with the old injector. And when you get the oil rail off, be prepared for lots of oil to come out of it. I leave it laying in the rocker box after I bust it loose to bleed out.
Old Sep 12, 2014 | 10:06 PM
Restlesswildman
Well I put the injector replacement off awhile and it is time to deal with it.
Truck is starting to puff BLACK smoke on any type of acceleration.
In the morning I am going to go get an injector and hold down hardware from the local Ford SD dealer in town.
I went to O'Rielly's tonight looking for a long T40 socket. They only had a 4 piece set and each was only approximately 4 inches long. Is this going to work for me?
Old Sep 13, 2014 | 06:22 AM
mustang_309's Avatar
mustang_309
I used a 1/4" breaker bar for this and it worked great.
Old Sep 13, 2014 | 09:27 AM
CPB1's Avatar
CPB1
Snap On SDMT440 torx bit and a bit holder to hold it. This is recommended for the pass. side.
^^^^ This was somewhere in the tech folder. It's just the correct length.
I bought 2 of the bits from Snap On and I bought this bit holder
SK Hand Tool 45498 3/8-Inch Drive Bit Holder Socket, 1/4-Inch, Chrome - - Amazon.com SK Hand Tool 45498 3/8-Inch Drive Bit Holder Socket, 1/4-Inch, Chrome - - Amazon.com
but have not used it it yet.
I will be doing 2 injectors next weekend, gonna order form Auto Nation Ford about $200 + core. Mine are on the driver side.
I have not done it but you can remove the heater box cover and get a little more room to work.
Old Sep 13, 2014 | 06:39 PM
Restlesswildman
Well it took me 30 minutes to get down to the 3 pain in the a$$ valve cover bolts. 30 minutes to get the 2 by the a/c heater box out. 15 to figure out how to get around the rear A/C lines between the valve cover corner and firewall for the end bolt.
I have one 8 mm bolt to get out on the rail. It is the last lower one by the a/c heater box. I can not for the life of me get anything on it and stay on as I try to take it loose.
Old Sep 13, 2014 | 07:50 PM
CPB1's Avatar
CPB1
You can remove the inner fender well and get at it from there. You can also remove the remove the cover on the a/c heater box and get a little more room.
When I removed the rail on that side I didn't remove the cover, I removed the inner fender well and got to it from there with a 1/4" breaker bar and a t30 bit that I ground down. I duct taped the bit to the socket to keep it from falling down in the engine. It was still a PIA.
Old Sep 13, 2014 | 09:00 PM
Restlesswildman
Ok I took a break......sat and pondered.....remembered where my 1/4 breaker bar was.....
Thought about removing the fender well........thought otherwise on it....added work! I am always the one to spend the extra time the 1st time to figure out a time saving short cuts on disassembly and assembly. Not quality work short cuts!
So as I was getting upset again.....I had an epiphany and whacked 3/8 of an inch off of my 8 mm deep well socket. This allowed me to get the breaker bar and scoket on that pesky pain the a$$ bolt!
Rail is off but and I am done for the night! I bought the extra long torx bit set when I should have bought the shorter set. Another tool for the collection!
So I will hit the parts store in the AM get the right socket and go from there.
BTW the trick with the socket to push out the injector plug.....that didn't work for me...I tried a 17, 18 & 19 and nothing happened.
I ended up using 2 screw drivers and 2 hands to get it out.
So if I didn't have the learning curve I am at 45 minutes of actual labor!
Old Sep 13, 2014 | 09:20 PM
CPB1's Avatar
CPB1
Sorry Restlesswildman I thought you had the wavy oil rails, I didn't you are working on an 03.
Great idea on the 8mm bolt ^^^^. Sometimes you have to do things like that with these trucks.
Old Sep 14, 2014 | 05:02 PM
Restlesswildman
Injector is in and she is alive!
Truck is sooooooooooooo much smoother!
Total working time is about 4.5 hours. I was moving slow and didn't have much motivation this weekend.
The biggest thing with doing this for the first time was not knowing the hang up spots and the work arounds for them. The 2 hardest things were the rear valve cover bolt by the rear a/c and heater lines and the last 8 mm oil rail bolt.
Once I cut an 8 mm deep well socket down for the rail it was a snap!
I would like to know how the dealer techs get around those heater and a/c lines on the Excursions!
A big learning curve on this job for me. I feel much more comfortable with doing an oil cooler after this weekend!
BigSix1
Jun 22, 2024 11:57 AM
Thehamburglar
Apr 12, 2019 06:23 AM
kwztoy
Sep 12, 2013 08:09 PM
mark121268
Oct 10, 2012 09:11 PM
randallc
Paint & Bodywork
Jun 28, 2003 07:53 PM
