Fuel Bowl Delete?????
Old Jun 18, 2014 | 12:31 PM
bobiker's Avatar
bobiker
What are the advantages of deleting your fuel bowl?
Is it an issue in cold weather?
Old Jun 18, 2014 | 12:44 PM
BigAlsPSD's Avatar
BigAlsPSD
Most who delete the bowl are doing so because of modifying the fuel system to a adjustable regulated return or larger lines or other fuel system modifications for more flow with larger injectors.
I guess that would depend on how cold we are talking. Many run without the fuel bowl heater, due to the possibility of shorting and taking out the PCM fuse, even in northern climates.
Old Jun 18, 2014 | 01:25 PM
Pikachu's Avatar
Pikachu
If the fuel filter housing is deleted, the fuel heater is unnecessary. The fuel flows through the heads where it's heated by the engine before being returned to the tank. This is where the, "if I delete my fuel filter housing, do I need a fuel cooler for summer" questions begin . . .
Old Jun 18, 2014 | 09:37 PM
jetdoc's Avatar
jetdoc
I noticed a 5 psi drop in fuel pressure today during a 200 mile run in 90 plus OAT. My stock fuel heater has been disconnected for years. I have Dennis' regulated return.
Old Jun 18, 2014 | 09:47 PM
Pocket's Avatar
Pocket
Depends.
For me I had two of them crack along the bottom for no apparent reason. So I deleted it because I was pissed. But now that it's gone, much easier to get to other stuff. So that's a plus.
Filters are cheaper and last MUCH longer than the stocker.
It was a PITA job to do, I ripped out the entire fuel system from tank to heads. Your experience may differ.
Is it an issue in cold weather?[/QUOTE]
Nope. Never had an issue.
Old Jun 21, 2014 | 07:49 AM
bobiker's Avatar
bobiker
Do you buy a kit or just piece it together as you go. You need a filter post tank, regulator, that really it?
Old Jun 21, 2014 | 07:55 AM
greg_8507's Avatar
greg_8507
Thats it. I would look into piecing one together. All the kits that I've seen are outrageously expensive. You can probably find a kit online and view the install instructions to get an idea of what all you need to do.
Old Jun 21, 2014 | 08:23 AM
bobiker's Avatar
bobiker
Kind of what im getting at outrageously expensive. Check this out then all you need is filters? http://www.strictlydiesel.com/p-2807-fuel-bowl-delete-upgrade-kit.aspx
Old Jun 21, 2014 | 08:42 AM
mueckster's Avatar
mueckster
I got lucky and was able to purchase the fuel bowl delete block, SS hard lines, regulator & mount, plus fittings from another member that reverted his back before trading it in. It also came with filter mount and filter. I chose to fab up my own hoses, using 3/8" synthetic lined nylon braided ones and JIC connections. My total cost for everything, including fuel pump & filters, was about half of a kit price.
Old Jun 21, 2014 | 09:03 AM
greg_8507's Avatar
greg_8507
That's an upgrade kit for a fuel bowl delete. That you could improvise by either using a 3 way tee and some teflon lines, or you can make some hard lines. Or if you can get ahold of a scrap block of billet aluminum, drill and tap the holes yourself. It looks very similiar to the FRx.http://www.riffraffdiesel.com/fuel-rail-crossover-frx/
Old Jun 21, 2014 | 09:09 AM
bobiker's Avatar
bobiker
So it is pretty much a point of connection for your lines. You would still need a regulator?
Old Jun 21, 2014 | 09:28 AM
greg_8507's Avatar
greg_8507
yes, you still need a regulator. I'm now curious as to how feasible it would be to use the regulator that is already in place. It's basically a spring and valve in the line coming off of the fuel bowl. I would have to pull it off and look at it, but it shouldn't be too complicated.
Old Jun 21, 2014 | 04:14 PM
greg_8507's Avatar
greg_8507
You'll also want to add a fuel/water separator.
bushman31
Nov 2, 2010 11:45 AM
quaziee
19
Dec 24, 2008 01:48 PM
j tate
Dec 21, 2008 11:19 PM
jayrak
26
Dec 13, 2005 10:37 PM
