geling fuel
Old Dec 21, 2008 | 05:10 PM
quaziee's Avatar
quaziee
geling fuel
Hello all, just a quick question before i make a mistake. I live here in lovely cold michigan, and this winter is no exception for being cold. My 84 f250 6.9 is having problems starting due to geled fuel. I was wondering if i could take household pipe heat tape to warm up the fuel lines. any idea? will this work or dont dare try this.
Thanks
David
Old Dec 21, 2008 | 05:23 PM
starmilt's Avatar
starmilt
Seems like there is a lot of gelled fuel problem this year where is everybody buying their fuel. The reason I ask is most truckstop fuel in colder climates is blended and we never have trouble in the big trucks anymore. Use howes and double up on it's dosage and #2 fuel will not gel even at extreme temps. I just made the trip to ak and never paid the extra price for #1 and even the fuel in my 110 gallon tank in the bed with no warm fuel returning to it never tried to gel. Anywhere north of edmonton the fuel is all blended no straight #2 available that I know of until you get to ak.
Old Dec 21, 2008 | 05:25 PM
1967 Turbo 6.9's Avatar
1967 Turbo 6.9
We've had 6deg weather here the last few days and I've not had any trouble. I don't plug in the heater. I've been hearing that this new fuel We're running on now will not gel.
Old Dec 21, 2008 | 05:33 PM
starmilt's Avatar
starmilt
There is a sign just north of coldfoot saying the ulsd is not guaranteed to burn past this point.
Old Dec 21, 2008 | 06:38 PM
1967 Turbo 6.9
How far north do You have to go to find Coldfoot =)
Old Dec 21, 2008 | 06:48 PM
starmilt's Avatar
starmilt
250 miles north of fairbanks not sure if the sign is still there or not that was winter before last.
Old Dec 21, 2008 | 07:06 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I would switch fuel supplier. I use Shell and Marathon. Haven't had a problem yet. If you are having a problem use a diesel fuel additive for gelling available from TSC and truck stops.
Old Dec 21, 2008 | 07:16 PM
starmilt's Avatar
starmilt
Shell and every other brand comes out of the same hose at the rack the differance is some small stations convenience stores etc. do not require the tankers to cleanout between products and the volume they sell. I have not had a gelling problem in several years but buy all my diesel at high volume truckstops.
Old Dec 21, 2008 | 08:27 PM
chris1066's Avatar
chris1066
I always run power service in the winter and have not had any problems yet.
Old Dec 21, 2008 | 08:41 PM
quaziee's Avatar
quaziee
I was getting my fuel from speedway. stop that about a month ago, there fuel was cloging my filter. So now i get it at marathon. I have diesel 911 in my tank and my fuel filer is about half full of the stuff. my problem now is i need to thaw out my lines. I have no garage so i was wondering if household heating pipe tape would work. any ideas? after i get her up and running I'm only going to fill up and the truck stop about 10 milies away. hope that will fix my problem.
David
Old Dec 21, 2008 | 08:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
ULSD has a problem with wax drop out at low temps.
From an article I was reading a couple nights ago, WDO or wax drop out can occur at temps above even the cloud point of diesel.
Remember, the fuel is blended for average temps.
I don't think what most of the mid west is seeing right now is average considering what we have seen for the last several years.
Read this article.
CFPP vs CP
Old Dec 21, 2008 | 08:51 PM
starmilt's Avatar
starmilt
In the old days we used to mix a little gasoline in the diesel if we were having gelling problems. Never tried the tape I have wrapped a tarp around the bottom and used a heater even used coals a time or two.
Old Dec 21, 2008 | 09:08 PM
Dave Sponaugle
Back about the time these trucks were new, I was running 10% gasoline when temps got this low.
150 gallons of fuel, 15 gallons of gasoline per tank.
Old Dec 21, 2008 | 09:13 PM
starmilt's Avatar
starmilt
That is about what we used some of the best winter fuel I burned in the old days was transfer oil out of junk transformers.
Old Dec 22, 2008 | 08:31 PM
84 f250 6.9's Avatar
84 f250 6.9
try wrapping a heating pad or hot rag around your fuel filter and plug it in over night i started mine today right up and its below 0 here (lik -18 w windchill) p.s. the filter in the engine compartment its proly not gelled just movin slow in the filter a lil heat should help
