Continuing brake issue. Need some help?
Old Jun 16, 2014 | 10:31 AM
Redfridge's Avatar
Redfridge
Hi friends.
99 explorer v-8 Eddie Bauer xlt. Awd cruise etc.
Master cylinder thread here...
https://www.ford-trucks.com/forums/1...-cylinder.html
Well. Replaced the master and took it in for a power flush/meaning the put fresh fluids in and bled the system.
The initial problem essentially is the brake pedal "steps or creaks" its way down.
It's intermittent but gets progressively worse I have found.
After the master and flush the problem went away for about a week and a half.
I have one abs code and that's the right front sensor.
Now I wouldn't think a sensor would be the issue.
What could it be?
Am I looking a booster issue?
Feels like an air in the line issue but the lines look fine and not losing any fluids.
Any ideas? Need to get this resolved. It's my daily.
Would a booster do this? Never had a booster fail.
Any common issues I'm missing with this model year?
Don't want to keep throwing money at it and would rather avoid the dealer.
Thanks to those who have helped or are willing to help.
Old Jun 16, 2014 | 09:43 PM
Mikeman's Avatar
Mikeman
Just thinking out loud here. I don't claim to know the detailed logic of the ABS system and how it interprets bad sensors or sensors with in-range failures. But, if the sensor has failed in-range and gives the computer a valid but erroneous value, then maybe the computer is applying the ABS. Maybe you could simulate a hard failure of the sensor by unplugging it and then taking it for a spin to see if the problem occurs. The computer should have no problem interpreting an open circuit as a failure. When the sensor on mine was bad, it failed open circuit. The bearing was worn, which allowed the "ring gear" to contact the sensor. I replaced the whole bearing assembly, which included a new sensor. I removed and checked the old sensor with a DMM to confirm that it was open. You could also see where the contact occurred on the end of the sensor. You might also want to check your wheel bearing.
Sometimes, disconnecting and re-connecting an electrical connector will fix things. Pins/sockets get corroded and separating them can remove the corrosion. This has happened twice on my AC system.
I'm also wondering if there's an internal leak or air in the ABS circuit or maybe you got a bad replacement master cylinder with an internal leak.
Old Jun 17, 2014 | 01:05 AM
Redfridge's Avatar
Redfridge
I'm thinking a possible air leak but I've checked all bleeders and connections.
It feels like air but not so sure.
The pedal steps or chunks down when it occurs.
Old Jun 18, 2014 | 10:01 AM
critterf1's Avatar
critterf1
Air is being introduced into the system from somewhere. The ABS systems code will have nothing to do with this problem.
Old Jun 18, 2014 | 11:09 AM
Redfridge's Avatar
Redfridge
Any common areas I could be missing as it pertains to an air leak?
Known brake line areas?
Cannot find anything as of yet.
Old Jun 18, 2014 | 04:18 PM
Redfridge's Avatar
Redfridge
I've checked every line and connection. I see zero leaks.
Is it possible that air could be getting in through my caliper pistons somewhere?
The rubber lines from the frame to caliper look good.
Jesus it's killing me.
Had em bled and felt great for about a week...now it's back.
Now I have an abs left front sensor code that's been unattended since I bought the rig.
Need to replace the sensor.
Could it be that the ABS speed sensor is losing some 'signal' from the disc, confusing the ABS system and cause it to randomly kick in causing an air in the line feeling?
Any ideas?
Again I appreciate the help. Be lost without you guys.
Old Jun 22, 2014 | 01:07 PM
Redfridge's Avatar
Redfridge
Alright I've narrowed it down.
Removed the #14 fuse for the ABS.
I have a bad left front sensor that's been showing codes for awhile.
Since removing the fuse....no issues.
So going to replace the sensor and hope that resolves the issue.
Anyone have a cheap sensor source?
I can buy a whole hub with sensor for cheaper than just a sensor at Oriellys.
Any ideas?
Thanks guys.
Old Jun 23, 2014 | 12:50 PM
Redfridge's Avatar
Redfridge
As of right now I know this.
It's the abs somewhere.
Breaks work fine with new master cylinder....no air in system.
I will next examine the sensor and connection on the front left.
Hope to god it's not the abs pump.
Thinking this faulty sensor is causing the system and brake pedal to do weird things.
Old Feb 5, 2016 | 04:47 PM
ilikemich's Avatar
ilikemich
Any luck? Similar prob, but with ford explorer xlt 1999 v6 4.0 2wd
Hi there. I know these posts were from a while back, but did you ever fix this? I have a ford explorer xlt 1999 v6 4.0 2wd that I replaced the wheel bearings /seals and upper/lower ball joints, and now when I brake, there's an intermittent crunching sound. It seems to only occur at slow speeds (under 10mph). I'm curious what fixed yours.
Old Feb 11, 2016 | 10:09 PM
darkAcolyte's Avatar
darkAcolyte
hey i had a problem like this one it rly sucks firstly is ur abs light on. if it is take out the fuse and drive it if it doesnt do it then one of the sensors is bad happened to me out of nowhere. let me know what u find always like to learn more
Old Feb 12, 2016 | 06:05 AM
Redfridge's Avatar
Redfridge
It was a bad sensor.
Check them all. If one of them touched the ring, it was probably damaged.
It's was cheaper to buy a new hub with sensor than just one sensor. Go figure.
Old Feb 12, 2016 | 06:45 AM
darkAcolyte
glad u found it and i hate how the sensors are integrated nowadays makes u have to but the whole hub
osage
15
Aug 16, 2012 07:54 PM
jkdank
Aug 6, 2008 08:38 AM
93f1505.0L
Mar 31, 2007 10:27 PM
Leeland1
Jan 29, 2004 03:14 PM
borland
May 15, 2002 11:40 AM
