Brake Problem, 95 Explorer XLT
Old May 13, 2002 | 12:31 PM
borland's Avatar
borland
Have a problem with my brakes that I can't figure out where the problem might be. Here's the symptons:
City driving at speeds around 35-40. During hard braking, sometimes the brake pedal feels like crushing an aluminum coke can. Requires more pedal pressure than normal for this type of stop. Doesn't do it every time, only maybe once a month. Corrects itself immediately, so its fine on the next stop.
Could this be associated with the ABS? Master cylinder? Power booster? Any help or similar experiences appriciated. Thanks in advance.
borland
Old May 14, 2002 | 06:32 PM
CNTHOR's Avatar
CNTHOR
Probably something with the ABS system.
Does it usually happen when your braking AND hit a small bump or bounce?
If so then your rear axle ABS sensor may need to be looked at
Does it feel like the pedal is pulsing when this is happening?
This also indicates a ABS issue
I believe you can disable your ABS system by pulling one connector from the right side right behind the headlight.
If you do this and the problem goes away then it definetly is your ABS system.
(the front sensor are only $20.00 and should be inexpensive to have changed. The rear sensor requires more work)
Old May 14, 2002 | 08:10 PM
ROMEO4894's Avatar
ROMEO4894
It sounds similar to the problem my dad had with his 94 ex. Air was caught in the brake line it took him forever to figure it out. He took out all the brake fluid and drained it until it was all out. Then carefully filled it back up. It took along time but it has been 2 years and it hasnt happend again. I dont know if that helps but its worth a try.
Old May 15, 2002 | 11:28 AM
borland's Avatar
borland
Thanks! Air in the line might be it. In addition to the crunchy pedal feel, it does seem like the pedal goes down further when the problem occurs. Why it only does it some of the time, and not always puzzles me?
I did have the brake lines flushed with new fluid after I redid the brakes. But that was when I purchased the car about a year ago, and it seemed fine then.
borland
Old May 15, 2002 | 11:40 AM
mingerso's Avatar
mingerso
borland
Jul 28, 2005 11:27 PM
borland
Mar 12, 2004 01:58 PM
borland
Aug 26, 2001 11:12 PM
borland
Apr 5, 2001 12:41 AM
borland
Mar 17, 2001 05:31 PM
