EOT sensor issue?
Old Jun 16, 2014 | 07:17 AM
jfletcher72's Avatar
jfletcher72
EOT sensor issue?
I am using a SGII to monitor my temps. The EOT is fluctuating several degrees during normal driving conditions. For instance this morning it was 80F outside. At highway speeds the ECT was 197F and the oil would go from 190 to 200F in just a couple of seconds. It would also read a little lower than ECT at times. Would this be indicative of a faulty sensor? Any assistance would be greatly appreciated.
Recent changes:
- a new tune for the SCT tuner.
- flush and fill on radiator. I did disconnect/reconnect the the fan sensor, and also removed/replaced the thermostat when doing the flush.
- oil and filter(OEM) change.
Old Jun 16, 2014 | 01:19 PM
jfletcher72
Nobody has had experience with any issue like this??? I guess a better question would be what happens when the oil temp sensor fails? Should I see a code?
Old Jun 16, 2014 | 01:29 PM
Money-Pit's Avatar
Money-Pit
After the truck sits overnight (at least 10 hours) post what your ect, eot and trans temp sensors read.
Based on your description, it does sounds screwy.
Old Jun 16, 2014 | 01:30 PM
jswartz84's Avatar
jswartz84
Have you tried reseating the connector to the sensor?
Old Jun 16, 2014 | 01:57 PM
jfletcher72
haven't tried re-seating yet....just noticed it on the way into work...but I will.
Old Jun 16, 2014 | 04:19 PM
bubba_78363's Avatar
bubba_78363
I had similar issues with my ECT sensor. One minute it was 5 degrees off EOT, and the next it was almost 30. Pulled connector off of it and put it back on and haven't had issue for almost two weeks now. (knock on wood) Agree go with the cheapest and easiest first. Good luck.
Matt
Old Jun 16, 2014 | 05:23 PM
jfletcher72
Thanks guys...ill check the connection first...
Old Jun 16, 2014 | 05:38 PM
jfletcher72
Well....sensor connector seated firmly...and the wires look to be in good shape. Would a faulty sensor cause my symptom??
Old Jun 16, 2014 | 05:49 PM
jswartz84's Avatar
jswartz84
Could be, swap it with the ECT sensor and see if the problem travels with it.
Old Jun 16, 2014 | 06:20 PM
jfletcher72
ill try that..... thanks.
Ryan Perko
Oct 12, 2017 12:23 PM
hoytfan99
Feb 28, 2013 07:47 PM
rwdfan
Jan 3, 2012 10:42 PM
bullit340
Sep 11, 2007 04:06 PM
mchild
May 28, 2005 02:53 PM
