Sponsored by: Real Truck
oil temp sensor?
Old Sep 11, 2007 | 03:07 PM
bullit340's Avatar
bullit340
oil temp sensor?
code p1184- oil temp sensor out of self test range
does this mean the sensor is bad and if so might it effect fuel mixture causing a motor to have gas ping? Its a 5.4 3 valve
Old Sep 11, 2007 | 04:06 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If it's one of those codes that keep it from going completely into "Readiness", it might.
(Readiness means all the PCM's diagnostics are passed - O2 sensor stuff, etc - otherwise, it just runs on a pre-set map and might not listen to the knock sensor if there is one)
