Sponsored by: Auxito
1997 Fuel Filter R & R solution
Old Jun 13, 2014 | 09:39 PM
96Aerostar's Avatar
96Aerostar
One of the darn slip coupling would not release. We had the correct tool and the first one come out in a few minutes, the second fitting was a struggle, after 20 minutes no progress. So we pulled the special tool out and put some Triflow (Teflon in oil) lubricant and it slipped a 1/16 of an inch more and released. I expect WD 40 or similar would also work.
We followed directions we saw on a YouTube video, very nice instructions. Easy to follow
Be sure to pull the fuse, yellow 20amp, from fuse box under the hood and disconnect negative battery terminal.
Thanks for all the great advice from all of the other members, you have helped me many times.
So it is my turn to give back.
96Aerostar
Old Jun 13, 2014 | 10:31 PM
shooter123's Avatar
shooter123
good advice. thanks!!
Old Jun 14, 2014 | 12:30 PM
projectSHO89's Avatar
projectSHO89
There is no need to do either.
You should relieve fuel pressure, though. There are multiple ways to do so safely.
Old Jun 14, 2014 | 04:13 PM
acogoff's Avatar
acogoff
Ford manual says to bleed pressure at shrader valve on fuel rail, but much easier, for me and less messy and safer, is to pull fuel pump fuse in under hood box and try and start engine. Pressure will be gone in a second or two into engine. Only fuel to leak is what is inside of old filter. All told a 4 minute job tops.
melo yelo
Mar 23, 2008 05:42 PM
macm
Nov 26, 2007 05:21 PM
dansV10
Modular V10 (6.8l)
Aug 14, 2005 09:55 AM
BLK94F150
Computer Chips & Tuners
May 30, 2004 05:40 PM
team green
Electrical Systems/Wiring
Aug 23, 2003 12:51 PM
