2001expo
Old Nov 25, 2007 | 03:16 AM
macm's Avatar
macm
2001expo
Just how hard is it to replace the fuel filter??? Quic Lube said they have a special for 49.95 and I said I'll wait!!!!!
Old Nov 25, 2007 | 07:13 AM
Modified 99's Avatar
Modified 99
It is not TOO difficult. You need the fuel line disconnect tool. Fuel filter takes about 20 to 30 minutes.
Old Nov 25, 2007 | 01:36 PM
dmorgan's Avatar
dmorgan
not too bad to replace, bleed fuel system pressure either by pulling fuel pump fuse and starting engine till it dies or by bleeding the shrader valve on the injection rail left hand side top of engine. then use the release tool to remove the filter i got the tool from autozone for about five dollors. a little fuel will spill as you change it so have new filter ready to pop back in as soon as you take old one out
Old Nov 26, 2007 | 05:21 PM
macm's Avatar
macm
Thanks guys, I didn't think it was a $50 job. Auto Zone has the filter for 9 bucks, my time is pretty cheap!!! Need the fuel line tool sounds like,still,15- 20 bucks???OK!!
