Fuel filter install question
Old Mar 23, 2008 | 09:02 AM
melo yelo's Avatar
melo yelo
Well kind of, how do I depressurize the fuel system so I can install the fuel filter with the least omaount of fuel going every where. Truck is 92 F-350 with a 351W. I know on most vehicles there is a switch or at least a fuse to pull, so where do I begin.
Old Mar 23, 2008 | 09:21 AM
EPNCSU2006's Avatar
EPNCSU2006
I would pull the fuel pump relay in the under hood fuse panel, then crank the engine over a few times until the fuel pressure has been relieved.
Old Mar 23, 2008 | 09:50 AM
melo yelo's Avatar
melo yelo
Is it labeled or numbered? I haven't even looked at the underhood fuse box just the interior one.
Old Mar 23, 2008 | 10:55 AM
Biglame's Avatar
Biglame
I would recommend the night before take some penetrant and spray the two fuel filter connections. To relieve the fuel pressure, there is a valve on the left side of the engine bay (it looks like a tire valve on the fuel line). They sell tools for this or you could use the blunt end of an 1/8 drill bit. There should be very little fuel loss, the only loss will be from the filter itself.
Old Mar 23, 2008 | 01:04 PM
melo yelo's Avatar
melo yelo
Is the valve on the fuel rail or the fuel line?
Old Mar 23, 2008 | 02:10 PM
quicklook2's Avatar
quicklook2
relay # 2.
Old Mar 23, 2008 | 05:42 PM
t4kne's Avatar
t4kne
the valve is on the line/rail as you said. right on top of the engine on my vehicle
