Set plug gap based on engine age/type or ignition system?
Old Jun 10, 2014 | 12:23 AM
1981fordstepside's Avatar
1981fordstepside
I had a quick question about the gap on spark plugs.
I have an 81 F-150 DSII ignition
it however has the engine block which is a 1971 based on casting #.
So do I set my plug gap to the recommended gap for the 81 302 DSII which I recall being around .44 ish or to the engine age which is around .35 for a 71 302. It was set to .35 when I first got the truck and hadn't figured out it was an older engine transplanted in there.
I set it to the ignition system seemed like a good bet seeing as it is the end point of the ignition system.
Old Jun 10, 2014 | 01:15 AM
FordFETruck's Avatar
FordFETruck
Set it to whichever ignition system you are using. If you're using DS II, set it at the recommended .042"-.044" gap. The 1971 .035" rating is for points and condenser ignition systems.
qbert
Sep 10, 2010 11:51 AM
Spydycarnge
Jan 6, 2010 09:22 AM
OzarksFord
Sep 29, 2006 11:41 AM
ms_michelle
Sep 2, 2004 06:43 AM
snowyowl
Mar 4, 2002 01:56 AM
