HELP dwell time and spark plug gap
Old Mar 3, 2002 | 04:24 PM
snowyowl's Avatar
snowyowl
I have a 351C with electronic ignition. What would be the electronic ignition timing or dwell time. Also what would be the spark plug gap? Plugs are NGK UR4 stock 6630.
Old Mar 3, 2002 | 09:17 PM
GT40man's Avatar
GT40man
according to ngk's site the plug gap is .035. dont know about the EI information. we didnt have EI on clevelands here in the states.
Old Mar 3, 2002 | 09:21 PM
Franklin2's Avatar
Franklin2
There is no dwell adjustment on an electronic ignition without points. Since it sounds like this is a modified engine( I don't think 351c had electronic ignition), you will have to experiment. Around 10 degrees BTDC would be a good starting point. The plugs can be gapped .035 to .045 which would be a conservative setting. You can gap them wider for more power, but they will need to be changed more often.
Old Mar 3, 2002 | 09:40 PM
thelonerangerxlt's Avatar
thelonerangerxlt
If it is a Ford Duraspark ignition, with the high voltage coil, the sparkplug gap should be .044".
Old Mar 4, 2002 | 01:56 AM
canzus's Avatar
canzus
F-100CustomCabTBC
Jul 2, 2013 10:22 AM
dreadinger
Jul 31, 2005 12:27 PM
handx2
Apr 27, 2005 11:54 AM
sledhead56
401, 477, & 534 SD Engines
Jun 18, 2004 10:39 AM
