Mods and swaps
Old Jun 7, 2014 | 02:05 PM
eddge's Avatar
eddge
Mods and swaps
How much custom stuff would need to be done to put the engine (351m), tranny, transfer, axles and suspension from a 77 F150 into/onto a 66? I'm not thinking it would be hard, as long as the 66 is wide enough right? Drive shafts may have to be changed because the 77 is a short bed. Would there be anything crazy I'd have to do that I'm not thinking about?
Old Jun 7, 2014 | 04:59 PM
jowilker's Avatar
jowilker
Other than that engine being a turd, bring the perches and it will bolt right in. You can swap the 77 I-beams and power steering all at the same time, for a power steering, power disc brake upgrade. All bolt hole exchange Ford factory engineered.
John
Old Jun 7, 2014 | 08:26 PM
LM14's Avatar
LM14
Think he is talking 4x4 since he mentions "transfer" in his question.
SPark
Old Jun 8, 2014 | 05:20 AM
jowilker's Avatar
jowilker
Spark, He'd be better off to move the sheet metal to the 77 chassis then. (If it's available)
John
Old Jun 8, 2014 | 09:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jowilker
Other than that engine being a smogged up turd very prone to cracking cylinder heads, bring the perches and it will bolt right in. You can swap the 77 I-beams and power steering all at the same time, for a power steering, power disc brake upgrade. All bolt hole exchange Ford factory engineered.
Power steering is not a 'bolt in' if the '77 has 4WD, neither will be the disc brakes.
1973/79 F100/150 short beds have a 117" wheelbase vs 1966 F100's that have a 115" wheelbase.
1973/79 F100/150 inner rear frame rail width behind the cab is 37 1/2" vs 1965/72's 33 1/2."
66f250
Jun 27, 2015 08:12 PM
mississippirebelride
May 20, 2010 03:38 PM
jakes66
Sep 17, 2009 05:16 PM
tankrsc
Feb 12, 2008 05:30 AM
lizardman1
Feb 11, 2008 04:15 AM
