front suspension swap
Old May 18, 2010 | 08:12 PM
mississippirebelride's Avatar
howdy from the deep south,,pleasure to be here and pardon my typonese ,,,just got my hands on a 65 lwb with a six and three on the tree,,, got it running ,but gonna fix some of the little things lifters seem a bit noisy,now my question can i replace the ibeams with those from a 79 so i can get the disc brakes,,and will the power brake booster bolt up?while i am at it will a later 70s power steering box work? thanx guys gonna go read all the posts and mayby figure it out myself..have a good night
Old May 18, 2010 | 09:20 PM
Bill W's Avatar
Bill W
First, Welcome to FTE!
second, read this link and it will answer some of your question's
f100discs
Old May 19, 2010 | 04:55 AM
jowilker's Avatar
jowilker
rebel, decide on how you want your truck's running gear to be when complete, and buy a 73-79 donor truck that has those parts. It then will be a matter of making a package like you want. Buy a piece here and there and you can have issues.
John
Old May 19, 2010 | 08:31 AM
banjopicker66's Avatar
banjopicker66
Welcome! From South Carolina!
I second John's advice, it is what I did a few years ago. I found a '76 F-150 with the engine, transmission, A/C, power disc brakes and power steering combination that I wanted and transplanted it all into my '66.
Then, I sold parts off the donor truck, and then scrapped the hulk and made more tan I paid for the truck to begin with, so all my upgrades were free.
Again, Welcome to FTE!
Old May 19, 2010 | 09:07 AM
SlickFreak's Avatar
SlickFreak
Welcome! Where in MS are you? I'm on the coast.
Old May 19, 2010 | 01:51 PM
Shaggie's Avatar
Shaggie
I just changed the brakes on my 66 with a 78 front end. Changed everything except the springs , arm off the steering box ,and the splitter boproprocinaning valve) [alot of us don't know how to sphell]. I'm planning to change the box and master cylinder when I change the rear axle. I even used all the new tierods and rubber mounts! I got the whole front end from a local junk yard for $100, I thought it was alot till I saw the new rotors and that the king pins were already changed. The only things I wish I would have gotten were the springs and antisway bar, but for that price who can complain? I only needed to use the torch once, and it took me about 2hrs and a couple of wiskie cokes, luckilly no bandaids.
look at what you are buying (donor or just a front end) and look at the parts you will need... you may luck out like me. Good luck!
Last edited by Shaggie; May 19, 2010 at 02:22 PM. Reason: forgetfull and a bad memory.
Old May 20, 2010 | 03:38 PM
thanx guys ,, as i had said ,,went and read alot of the old posts and duh,, lotsa answers and all very informative,,searching for a 78 donor ,,yhink i found one,,
