I-beam interchange
Old Feb 11, 2008 | 07:43 PM
tankrsc's Avatar
tankrsc
I-beam interchange
Ok the 2 trucks first is a '72 F-100 2WD strait six 3-spd short bed power nothing, Second truck is a '77 F-100 2WD 302/C4 long bed power brakes and power steering.
Question is this I know I have to get a bracket for the P/S pump on the motor and that is no problem, but can I just unbolt all the front suspension from the '77 and put it under the '72? I want the power disk and steering so will the steering box bolt up too? Do I also have to use the '77 steering colum?
Old Feb 11, 2008 | 08:02 PM
jhooch's Avatar
jhooch
Yes, the suspension from the 77 will bolt up under the 72. I did this exact swap. Easy. My '71 had power steering so I did not change columns. I used the steering linkage from the '77. Good luck.
Old Feb 12, 2008 | 05:30 AM
jowilker's Avatar
jowilker
I agree, jhooch is right on.
Everything from the 77 will direct bolt up on the 72.
John
