FICM issues and U0105 Code
Old Dec 13, 2014 | 09:35 PM
Yahiko's Avatar
Yahiko
Ed I have a silly though. What about worn pins?
Not bent but ones that are just a bit smaller or a
socket that has stretched a bit and when it gets hot
is expands more and breaks the contact.
To test that you would need a tool like this one with
the right pin and socket sets. Then you need to know
what the tension needs to be set to.
https://www.dmctools.com/default.html
That one in the photo is fairly beat up.
Old Dec 13, 2014 | 11:24 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
I've never seen worn pins on a FICM before - it just takes too much to wear on them. Of course, I *have* seen worn FICM plugs from harnesses, but that is mostly on our test bench harnesses that have seen way more use than the typical plug would of course EVER see.
I like the idea, though - at least it would be a reason for a module to work just great in one truck and either not start or stall out on another (even with the same model year and software).
We're up to maybe five cases of this at this point.
Kudos for thinking out of the box!
Old Dec 14, 2014 | 12:40 AM
Yahiko's Avatar
Yahiko
The one cause that I can think of that might explain that is
someone used a meter to probe the plug and opened the
contact up with it. Avation back ground is showing a bit maybe.
But when you need to see what is on a plug you do a back probe
or a breakout box with the correct plug for what you testing.
That way there is no risk to the connector you testing at. It happens
way to often and that is the reason for that testing tool.
Old Mar 7, 2016 | 01:47 PM
j.bagg19's Avatar
j.bagg19
did you ever resolve your issue?
Originally Posted by bigbeariron
What exactly should I be looking for? I have checked all connections at the PCM, and the Connector from the PCM to the FICM. Anything I can test for at the PCM?
I am having same issues, intermittent injector chatter, and it will only crank when their is chatter. All while i have voltage at relays and fuses, 48 volts on 1st screw under ficm cover both koeo and while cranking.
Old Sep 24, 2020 | 07:49 PM
Janus's Avatar
Janus
Looking to get in contact with the op
I'm having a similar issue with my truck. Just trying to see what the op did to resolve the issue.
OldWoodsDiesel
37
Jan 13, 2020 11:53 PM
Chris L Smith
Feb 20, 2018 12:11 AM
John Rice
Aug 18, 2017 08:23 PM
nomad221
May 10, 2012 03:24 PM
18vtx00
Jun 29, 2005 01:39 AM
