Hey everyone-
Got a leak in the fuel pump under the turbo yesterday. apparently I have the CA version of pump with that fuel buffer attached to the pump. The leak is coming from that POS. trying to get it off now. and the local parts stores have new pumps but they don't come with the new end piece with banjo bolt! is this a FORD dealer part or can i find one online?
Dealer only part. Ordered a non CA part from Carson City, NV, only 2 hours away, so this crack will never happen again. And possibly some better engine response. Replacing fuel pump at same time, might as well.
Having a hard time removing the banjo bolt. my 1-1/4" wrench is too thick to bend and still have enough clearance from the turbo mount. I would have removed the turbo this morning if the bolts weren't so difficult to reach and weren't seized. even the bolts i could access were unable to move after a night of pb blaster and the cordless electric impact.
