Fuel Pump Fuel fitting help
Old Jun 21, 2009 | 05:01 PM
chris64's Avatar
chris64
Hey guys, I got my new fuel pump on. But I'm really having trouble getting the fuel fitting on the back of the pump. should I loosen the turbo pedestal to give me some more room? It is a wicked PITA to get that fitting . thank you for any advice
C
Old Jun 21, 2009 | 07:37 PM
kawa's Avatar
kawa
Chris, I assume that you don't have a Cali truck. Have you tried to loosen the bolts holding the pump down, that should give you a little wiggle room to get that rear bolt aligned and started. Try that before you start tearing into the turbo mounts.
Rog
Old Jun 21, 2009 | 09:12 PM
chris64's Avatar
chris64
Ooh good call !!!! I will get on that ASAP tomorrow, I'm taking a personal sanity day... Iwill loosen the hose clamps a bit also.thank you, C
Old Jun 29, 2009 | 11:43 AM
Copedawg's Avatar
Copedawg
Well this may be a little late but here is how I changed my pump https://www.ford-trucks.com/forums/6...ml#post4782663 I hope this can helps
Old Jul 1, 2009 | 07:44 PM
chris64's Avatar
chris64
Thanks for the help, it took some patience.... but I got it back on.
Thank you, C
