Code P2284 - HELP
Old Jun 3, 2014 | 10:38 AM
jgdrcr's Avatar
jgdrcr
Code P2284 - HELP
Updated the egr cooler and when i got it back from the mechanic, it was not running smooth. This morning the idle is very hard and code P2284 popped up. Could this have occurred due to the egr cooler upgrade? Did the mechanic do something incorrect. Was running perfect before the egr cooler.
Any ideas what it could be or what i should look for. The mechanic was highly recommended and was told they specialize in diesel engines, which is why i took it to them.
Thanks for your help
___________________________
2007 6.0L 4x4 Lariat SB, 44,000 miles
Old Jun 3, 2014 | 11:48 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You have a leak in the HPO system somewhere.
It could be either dummy plugs or the STC fitting.
The STC fitting will cause a crank, no start hot condition. Whereas dummy plugs let you know you're on borrowed time with long, hard starts as an early warning sign.
I don't see how your mechanic could have handed you back a truck that wasn't running right. He really should have addressed atleast the STC fitting while he had the top side apart.
Old Jun 3, 2014 | 07:42 PM
BLADE35's Avatar
BLADE35
I agree on that mechanic
could be a loos wire he had it all apart
Old Jun 3, 2014 | 08:53 PM
04badford's Avatar
04badford
Make sure the ICP connection is fully clipped in, what are you seeing on ICPV
Old Jun 3, 2014 | 10:45 PM
bismic's Avatar
bismic
+1 . Also look for any damage to the connector or wires.
Could also be an IPR issue.
RedneckTrucker
6.7L Power Stroke Diesel
May 3, 2018 06:21 AM
cookingguy
Feb 26, 2018 10:09 AM
camperboy
Nov 18, 2017 08:37 AM
diesel stopper
Mar 16, 2016 01:33 PM
EMC V10 X
Nov 19, 2014 05:19 PM
