Code P0401 - EGR
Old Oct 9, 2017 | 03:24 PM
camperboy's Avatar
camperboy
Code P0401 - EGR
So my 13' has a issue at 76k on the clock. I keep getting the code for insufficient EGR flow. From what I'm seeing that is most likely a plugged cooler. Anything else I should check before swapping out that cooler?
Also, any comments on a Ford OEM part vs the likes of Dormane or Cardone? This **** is expensive so if a aftermarket is up to the task I'll consider it.
Up to now its been a couple exhaust bolts, get sensors and a confused DEF level that the dealer reset.
For those who might ask, I get to sit in a lot of stop n go traffic in northern nj. 25 minute drives frequently take a hour. Or more.
Camper
Old Oct 9, 2017 | 05:42 PM
m-chan68's Avatar
m-chan68
Clogged EGR coolers are pretty common on these trucks, depending on usage. The good news is they're not terribly difficult to replace, nor are they expensive to purchase OEM. This, I believe is the very reason the secondary cooling system no longer passes through the EGR cooler on 2015 and newer model years.
Old Oct 10, 2017 | 05:36 AM
radium's Avatar
radium
Got a really quick question for you most people post this code just curious how many engine hours do you have versus engine idle hours you can find this in your screen just curious to see my last truck was a 2016 head over 2000 engine hours and only 145 idle hours it was spotless inside when they took the motor apart thanks and sorry for your problem
Old Oct 11, 2017 | 06:19 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
I would say you need to stick with an OEM cooler should that be the problem. The aftermarket has it's place, but definitely not for replacement engine parts on newer diesel trucks. The quality of the parts is usually just not up to par.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Oct 11, 2017 | 09:54 PM
camperboy's Avatar
camperboy
radium - I'm not sure of the exact number of hours. What I can say is that I sit in a lot of stop and go traffic every day. Its well over half my daily drive time. Can't image that is good for it. I can say that I don't let the truck sit and idle much.
Justin - Thank you for your input on the parts. I had one of your tuners on my old 7.3 and it was a great product. I'd recommend DP any time and would turn to you again except the 6.7 already has so much power. Of course the trans could shift better.
Thank you all
Camper
Old Oct 11, 2017 | 09:57 PM
Bubba Bell's Avatar
Bubba Bell
Mine just threw the same code among others. This just after my reductant DEF heater replaced. Wonder if it's because the heater wad going out?
Old Oct 12, 2017 | 11:23 AM
Justin@DP-Tuner
PREMIUM SPONSOR
Thank you all
Camper
No problem.
Yes, we tune the 6.7L's now too. We even offer a Trans Only tune for guys like you who are happy with the engine power, but not with how the trans acts.
__________________
Justin
www.dp-tuner.com
Old Nov 13, 2017 | 09:23 PM
camperboy's Avatar
camperboy
Thought I'd come back with the final story. Took the truck into our local trusted shop. Sure enough, plugged EGR cooler and the EGR valved was loaded too. Odd, he said the carbon was kind of wet but he couldn't find any sign of a leak etc. At any rate its back on the road running great. Thanks for all the advice.
Camper
Old Nov 14, 2017 | 05:46 PM
DeeDubz's Avatar
DeeDubz
does anyone have a video on how to clean / replace EGR?
Old Nov 15, 2017 | 09:21 AM
254XP3's Avatar
254XP3
There are alot of vids on Youtube about this. Diesel Tech Ron, and FLMMAZ both had great videos showing removal/teardown/re-install. Might check them out.
Old Nov 15, 2017 | 01:33 PM
DeeDubz's Avatar
DeeDubz
Can anyone provide a link? I've searched but nothing that shows removal
Old Nov 15, 2017 | 05:10 PM
254XP3's Avatar
254XP3
Not sure if these will help. These first two don't really show removing bolts etc to remove, more of what it looks like when out.
This one shows what one person did on youtube to delete his EGR. Probably more of what you are looking for:
Old Nov 18, 2017 | 08:37 AM
DeeDubz's Avatar
DeeDubz
thank you !
diesel stopper
6.7L Power Stroke Diesel
Mar 16, 2016 01:33 PM
EMC V10 X
Nov 19, 2014 05:19 PM
TruckingBill
Aug 31, 2014 02:55 PM
jgdrcr
Jun 3, 2014 10:45 PM
sarnott140
May 9, 2012 08:49 PM
