Sponsored by: Real Truck
Larger Oil Filter
Old Jun 3, 2014 | 10:20 AM
speakerfritz's Avatar
speakerfritz
I don't know how good this list is nor do I know which is bigger....but I do know the only filter I will use is MOTORCRAFT FL 820S.
MOTORCRAFT FL 820S replacement oil filters:
  • AC-Delco PF1250
  • AC-Delco PF1250CL
  • AC-Delco PF1250FCL
  • AC-Delco PF26
  • ALLIANCE ABP/N10G-LF3681
  • AMSOIL ASF11
  • AMSOIL EAO11
  • ATLAS F-20
  • AUTOEDGE AL2
  • Autolite for Oil Filters AL2
  • AUTOPAR FE336
  • Baldwin B329
  • BIG A 92372
  • Bosch 3410
  • Bosch 72212
  • CAM2 C4651
  • Canadian Tire 17-1738-2
  • CARCARE IOF2
  • CARQUEST 84899
  • CARQUEST 85372
  • CARQUEST B4651
  • CASITE CF110
  • CASTROL CAS2
  • CENEX CO820
  • ChampLab PH26
  • ChampLab PH820
  • CHRYSLER 4884899AB
  • CHRYSLER 5038041AA
  • CITGO C4651
  • CROSLAND 2010
  • DEFENSE DL2
  • DELPHI FX1008
  • DENSO 150-1014
  • DEUTSCH D407
  • Donaldson P550965
  • Econo Lube L24651
  • EVERGARD E4651
  • Filters Incorporated OF2
  • FIRESTONE TF-4651
  • FIRESTONE TF4651
  • FLAG C-2
  • Fleetguard LF16002
  • Fleetguard LF16214
  • Fleetguard LF3681
  • Flying F PH2AZ
  • Fram PH2
  • GONHER GP68
  • GOODYEAR L4651
  • GRAND PRIX PH820
  • Grease Monkey GM24651
  • Grease Monkey GM4651
  • Group 7 V4651
  • HASTINGS LF110
  • HASTINGS LF612
  • HAVOLINE T-36
  • HENGST H10W18
  • JIFFY LUBE HL2
  • JIFFY LUBE JL4651
  • JIFFY LUBE L24651
  • K & N HP-2010
  • KENDALL K29
  • KRALINATOR L320
  • LEE LF-820
  • LUBER-FINER PH26
  • LUBER-FINER PH820
  • Mann Filter ML 1006
  • Mann Filter W920/16
  • Mechanics Circle MOF 2
  • MERCURY 35-877761K01
  • MICROGARD MGL2
  • MIGHTY M4651
  • MILEGUARD MO2
  • MOBIL M1-210
  • MOBIL MO4651
  • MOPAR FE00336
  • MOPAR MO-899
  • Motor Trend ML2
  • MOTORCRAFT FL 820
  • MOTORCRAFT FL 820S
  • NAPA 1372
  • NAPA 7899
  • Parts Master 61372
  • Parts Master 67899
  • Parts Plus PH820
  • PENNZOIL PZ-42
  • PERFORMAX PO-42
  • PHILLIPS 66 PO1372
  • POWER FLO SL24651
  • PRO/GAUGE PGO-4651
  • PRO-TEC 159
  • PROMOTIVE PH2500
  • PRONTO PO-2
  • Purolator L24651
  • Quaker State QS2
  • ROCKHILL 61372
  • ROVER 4137784
  • SECURITY SO-820
  • SERVICE 1 OF4651
  • SERVICE PRO M4651
  • SHELL SH36
  • SILVERLINE 21372
  • STP S2
  • SUNOCO O-35
  • SUPERTECH ST2
  • TRUST PH820
  • UNOCAL PF820
  • VALVOLINE VO105
  • VALVOLINE VO47
  • WALMI WS-2
  • WARNER PH820
  • Wix 51372
  • Wix 57899
OE Part numbers matching this oil filter:
  • Ford F1AZ-6731-A
  • Ford F1AZ-6731-BD
  • Ford FL 820
  • General Motors GM 19160693
  • General Motors GM 19160696
  • General Motors GM 89017527
  • Mazda AJ04-14-302B
  • Mazda AJ57-14-302
  • Mazda AJTM-14-302
  • Mazda GY01-14-302B
Old Jun 3, 2014 | 11:51 AM
dkf's Avatar
dkf
I would have liked a larger filter than the 820s on my 6.8l because it only has a 6 quart pan. I have found none and I let it at that. The 6.2l and later 6.8l engines have 7qt pans which is good enough. The 820S filter works and the anti drain back valve system works very well.(which is extremely important) I have had no problems with the 820S on any vehicle in the 15 years I have been using them.
Old Jun 15, 2014 | 02:08 PM
Mario428's Avatar
Mario428
The only thing I can say to most of the posters here is "you REALLY drank the kool-aid!!!!!!!!
Would this same superbly engineered truck be the same ones with the engines that BLOW SPARK PLUGS OUT OF THE ENGINE!!!!!!!!
Break steering box bolts off a truck that has never been off road!!!!!!!
Let the smoke out of multiple fuse boxes!!!!
I am a Ford guy but man they make it hard
When I hook up my trailer and I am moving 17,000 lbs total, I look at the size of that filter in dismay, no a bigger filter does not guarantee more filter media but a long Wix eg will have more than a short Wix, you guys need to get a clue
Old Jun 15, 2014 | 06:42 PM
Fleetsuper's Avatar
Fleetsuper
WOW!!!
I had no idea that asking a simple question fir a part number would garner such reaction.
More oil capacity is always a good thing. Whether you agree or not, I'm looking to increase my oil capacity. So....does anybody know of a larger Motorcraft filter that can be used on a 6.2L?
Old Jun 15, 2014 | 06:44 PM
MisterCMK's Avatar
MisterCMK
Originally Posted by Number21
Yeah...they also spent millions developing the 6.0. Did you see how that turned out?
As long as you don't do a bunch of short trips (the oil will never get to operating temp) adding more oil capacity is always a good thing. Even if there is no extra filter media.
The 6.0 is not a Ford motor bud. Navistar
BTW, the 6.0 oil filter is great. Easy to change, doesn't spill a drop and filters well.
jmmartin
Feb 5, 2010 05:54 PM
zstyle01
Sep 6, 2007 05:59 PM
rswhitmore
Engine Swaps
Aug 10, 2007 04:41 PM
rswhitmore
Oil & Lubrication
Aug 4, 2007 02:04 AM
bigbadwolfe
Mar 18, 2007 09:19 PM
