Compact Oil Filter
Old Jul 26, 2007 | 02:11 PM
rswhitmore's Avatar
rswhitmore
Compact Oil Filter
Has anyone seen or used a compact (short) oil filter that replaces the Motorcraft FL1A or Fram PH8A filters used on many Ford engines? I have some clearance issues with the oil filter on an engine swap, and a 'shortie' filter would be just the ticket. I saw one on a small diesel that is about the same diameter, but only about 2.5" long. I haven't been able to find it or similar now that I have a use for a short filter.
Old Jul 26, 2007 | 03:56 PM
EPNCSU2006's Avatar
EPNCSU2006
Ford used a short filter on engines equipped with an oil cooler. Those were found on some of the heavier 351's and 460's in these year trucks. I want to say that it is an FL820S if you want to give it a try. I don't know for sure that it is just a shortened version or if the threads or different or what.
Old Jul 26, 2007 | 10:33 PM
hoxiii's Avatar
hoxiii
Get an oil filter for a 1998 saturn sedan with an I-4.
Justin
Old Aug 7, 2007 | 11:46 PM
Matts72's Avatar
Matts72
The WIX part number is 51068 or 51085. The FL820s is a metric thread.
The 51085 is a Dodge filter that fits fine, the 51068 is a old ford filter for the cars that had a 90 degree adapter for the filter.
Old Aug 9, 2007 | 10:14 AM
Kruse's Avatar
Kruse
Prolly already answered by somebody else. But, go to your catalog and look up a oil filter for a '76 Mustang II with the 302 motor. It's about half the size of the FL1A and has the correct threads unlike the metric 820.
Old Aug 10, 2007 | 04:29 PM
EPNCSU2006's Avatar
EPNCSU2006
I had a suspicion that the 820S had metric threads, so thank both of you for getting that right.
Old Aug 10, 2007 | 04:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 Ford Passenger Car Parts Catalog
Engine Section 60.3; Page 14
1975/78 Mustang II 302 engine.
Motorcraft: FL-300
