SCT return to stock
Old May 31, 2014 | 02:24 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Disconnect the batteries again, leave them disconnected 1 hour or more.
Retry resetting the PCM to stock.
Still no start call SCT
Josh
Old May 31, 2014 | 07:24 PM
Maxium4x4's Avatar
Maxium4x4
The caps drain quick so as suggested, give SCT a call. Go over the truck again where you were working and re-check connections. Do only one task at a time, any interruption while flashing the truck can be bad news.
Old May 31, 2014 | 07:43 PM
maxtruck00's Avatar
maxtruck00
I have to give credit to SCT, they sent me a stock tune this afternoon!
Truck started, drove it home.
Before the coolant flush i never saw over a 9 degree delta, between oil and coolant.
after the Flush i'm seeing 15-40 degree delta on the CS monitor.
I even pulled over at one point because the oil temp was over 235. Coolant never got over 206.
Can the CS monitor be wrong?? Did the flush clog the oil cooler? maybe this has to do with the tune SCT sent me?
this truck is killin me!
Old May 31, 2014 | 08:38 PM
KIDkiser's Avatar
KIDkiser
If it was a straight water flush I can't see a difference in temps,BUT if you used any chemicals then yes you probably plugged the oil cooler.
Old May 31, 2014 | 11:22 PM
Yahiko's Avatar
Yahiko
Just how did you do the flush?
Even without any chemicals you "could" of kicked some garbage loose
that may of been just hanging. One thing you may want to try is to
back flush the oil cooler. If you have fresh coolant you should be
able to save it. Catch it in a clean bucket and filter it.
More on the Back flush if you want to take that step. Just let us know.
The first thing is to make sure that the sensors are all in agreement
after an 8 hour cols soak time. ECT,EOT and TFT should all be with in about 1º degree.
Sean
Old Jun 1, 2014 | 12:35 AM
maxtruck00's Avatar
maxtruck00
I did the coolant flush per the tech folder.
back flushed oil cooler, heater core, radiator,
installed Fumoto valves in the block.
chemical flushed with restore plus.
filled with Cat ELC
Coolant temps were awesome! Oil was boiling...
When i saw what the chemical flushed out of that engine, my first thought was that i'd be researching how to replace an oil cooler next.
I'll let it sit over night and try it again.
Old Jun 1, 2014 | 12:56 AM
Yahiko's Avatar
Yahiko
You have a plugged oil cooler. If back flushing the oil cooler does not
clear up the problem it's time for an oil cooler job.
The oil cooler job is not some thing that is that bad. Just take your time
and don't get in a rush or buy Dorman parts.
Have a look at the videos done by Srmastertech
Here is the play list. The cool thing about the play list is he
does a video on the tools that are needed and helpful to do the job.
Or one at a time and I hope I have them in the right order
Sean
Old Jun 1, 2014 | 09:41 PM
Maxium4x4's Avatar
Maxium4x4
Got the thread fixed.... somebody fat fingered a url
Truck-mutt
Sep 27, 2013 06:22 AM
murraydav
Oct 5, 2011 05:25 PM
rodolan
Jul 16, 2009 06:38 PM
borcht warrior
Oct 20, 2008 08:56 PM
wgawahoo
May 27, 2007 07:49 PM
