superchips download error--HELP
Old May 27, 2007 | 05:03 PM
wgawahoo's Avatar
wgawahoo
Angry superchips download error--HELP
On Friday I was changing program on my superchip and for some stupid reason turned on my ignition Error 6 showed on tuner.I unhooked batteries for an hour still truck wont start can anyone help with this
Old May 27, 2007 | 06:22 PM
Uzumati's Avatar
Uzumati
Have you tried reprogramming with the SC back to stock?
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
What does it say when you hook the tuner back up? Will it allow you to reload the stock program?
Old May 27, 2007 | 06:30 PM
wgawahoo's Avatar
wgawahoo
I have tried to return to stock programming but it wont even give me the option . I,m wondering if I screwed u-p right in between program changes and no programs were stored is it possible?
Old May 27, 2007 | 06:46 PM
Uzumati's Avatar
Uzumati
will it let you reload the performance tune?
Old May 27, 2007 | 07:11 PM
wgawahoo's Avatar
wgawahoo
it will not let me download any info -says communicating then says error 6 contact superchips
it seems like it cannot read any info at all
Old May 27, 2007 | 07:20 PM
Uzumati's Avatar
Uzumati
If you turn the key on does the WTS light come on? If not check all of the fuses under the dash and under the hood, several are tied to the PCM and could have popped, but It sounds like the PCM is stuck with a partial program and cant do anything.
Old May 27, 2007 | 07:21 PM
cookie88's Avatar
cookie88
FTE Emeritus
Contacting Superchips is probably your only option at this point.
Old May 27, 2007 | 07:37 PM
wgawahoo's Avatar
wgawahoo
as soon as Iplug in programmer it says "last programming attempt Failed"press > to continue --system inializing-Type 6 error call Superchips
Old May 27, 2007 | 07:40 PM
wgawahoo's Avatar
wgawahoo
If I remove the chip shouldnt I have stock programming left
Old May 27, 2007 | 07:49 PM
Ford79's Avatar
Ford79
Not if it's stuck in the programmer.
Sounds like a call to Superchips is in order first thing Tuesday morning.
