Ooops
Old May 30, 2014 | 10:08 PM
KDAVID1's Avatar
KDAVID1
Ooops
Had a bit of moisture on the roads today when I got off of work.
Was getting onto the interstate via an on ramp. Well I proceeded to roll into it like I do as normal to get up to speed and she broke loose on me--dang near got horizontal with the road. I'll have to change my throttle up procedure when its wet out.
Old May 30, 2014 | 10:24 PM
78fordman's Avatar
78fordman
What do you run for tires?
Sent from my leash using IB AutoGroup
Old May 30, 2014 | 10:49 PM
KDAVID1's Avatar
KDAVID1
just the ole standard a/ts that come factory right now-cant remember the brand right off. Got good tread left on em
Old May 30, 2014 | 11:00 PM
04badford's Avatar
04badford
was it a first rain in awhile? OIL on the asfault separates from water ,over here in Cali and fornia that is the way people drive ( all the time) Defence driving.
Old May 30, 2014 | 11:16 PM
9228.bobcat's Avatar
9228.bobcat
6.0 may just have to much power for you. Might need to check in getting a 7.3 or a dodge.lol
Old May 30, 2014 | 11:21 PM
KDAVID1's Avatar
KDAVID1
not an option
Old May 30, 2014 | 11:27 PM
KDAVID1's Avatar
KDAVID1
HAHA--we got those drivers here too. It's actually been raining since last Sunday off and on--that's why i was a bit surprised.
Could have been a little light on the rear end since I'm now down a bit lower than a qtr tank (rear mounted)
Old May 30, 2014 | 11:32 PM
04badford's Avatar
04badford
I always chuck the old lady in the back that holds the rear down, OH shoot is she's online now.LOL
Old May 30, 2014 | 11:57 PM
KDAVID1's Avatar
KDAVID1
hahahahahaha--now that is funny
no offence to your Mrs
Old May 31, 2014 | 12:24 AM
Yahiko's Avatar
Yahiko
Write me into you will. I want your truck and any trailers you have.
That is if she is willing to let anyone know you are no longer
among the living after that remark.
Sean
Old May 31, 2014 | 06:47 PM
Snuggyworm's Avatar
Snuggyworm
does it sound like the turbo just spooled and took off on u? tat happens. although i've heard a good fix is to install the wicked wheel 2 on our turbos. fix tat right up. another thing could be a new rear sway bar is in order. tat helps keep u planted on the ground too.
Old May 31, 2014 | 07:02 PM
KDAVID1's Avatar
KDAVID1
That could have been it--didnt seem like the case but makes more sense than anything else. I gotta take a look at the swaybar. Truck used to be a cab chassis--not sure the set up. Im saving money to do some upgrades-wheel is on the list
Old May 31, 2014 | 07:13 PM
Snuggyworm's Avatar
Snuggyworm
if it used to be a cab chassis, then expect the frame to be positioned closer towards the center, unlike a standard 4-wheel powerstroke. tat being said, ur center of gravity and equilibrium is shifted more towards the middle and setup to be sturdier for tat towing application. it's just plain old terrible when u turn either way and ur not as steady as a regular 4 wheel powerstroke.
if i'm not mistaken, all cab chassis and duallies have frames tat are situated closer towards the middle. mine is a pain when i try to drive it around corners like a BMW. fortunately, i have an extra set of wheels in the back and my new rear sway bar kit helps a ton!
hope this info helps.
Old May 31, 2014 | 09:25 PM
KDAVID1's Avatar
KDAVID1
It does help. Yep I was in a slight turn. You are correct on the frame too. The cab chassis is 3 inches narrower then standard truck and front to back is flat as a pancake. Will be looking into a different sway bar for sure.
MissIndependent
Nov 14, 2009 10:19 PM
nflfreak43
Tennessee Chapter
Jul 7, 2009 05:21 PM
RCrawler
1966 - 1977 Early Broncos
Jun 21, 2009 07:33 AM
iskybantilus
New Jersey Chapter
Oct 4, 2004 09:56 AM
Rupturedduk
New York Chapter
Sep 19, 2004 08:37 PM
