carb sugestion
Old May 30, 2014 | 09:14 PM
Big_Tom_54's Avatar
Big_Tom_54
I have a fairly stock 390 in my project truck, not sure the year I think it is titled as a 72, it's a F250 4x4 with said engine np435 and divorced np205 and the kicker is has a 54 body on it. My question is, since the carb is in dire need of a rebuild it leaks for a while til it reseals it self, rebuild the 2 barrel or upgrade to a 4 barrel? I have gathered parts for a 4 barrel swap. I have an intake from a 64 t bird with carb a linkage brackets. It's an iron intake and heavy but the truck isn't light to begin with. Can these old engines benefit from good carb? And what suggestions for a carb do you all have? I may tow a camp trailer with it or daily drive it a bit but it's not an off roader. Ask that has been done with the motor is it has a set of unknown headers and a tune up to get it running descent, then I found the carb issue.
Old May 30, 2014 | 09:42 PM
orich's Avatar
orich
Maybe the needle set is bad letting it flood gas out of it and, or float could be to high also.
Orich
Old May 30, 2014 | 11:41 PM
Big_Tom_54's Avatar
Big_Tom_54
That maybe but ask the seals leak it had sat a long time in an orchard.
Old May 30, 2014 | 11:53 PM
orich's Avatar
orich
Old T-bird intake had tall ports where as the later 390 have smaller ported heads Note good for a match. A 600 cfm auto-lite or motor-craft will give the best mileage. BUT NOT THE BEST POWER. Holley 600 cfm will give about the best but 10-11 mpg is about tops.
Orich
Old May 31, 2014 | 12:51 AM
Big_Tom_54's Avatar
Big_Tom_54
So I understand, for the bird intake to work properly the heads would need to be used to. Mpgs aren't a concern well cause the gas gauge move down faster then the Speedo moves up I think 9 is about the best I have gotten. I have read some about the Holley truck avenger carbs as well as the avs series from edlebrock. Side note, I saw a test of Holleys stand alone wide band oxygen sensor kit, used to tune the carb set ups for some pro touring cars. I am looking in to those kids for my truck.
Old May 31, 2014 | 10:09 AM
Turbo Dog's Avatar
Turbo Dog
A brand new carb is hard to beat...it takes alot to do a really good rebuild. Most of the older carbs I look at have worn out throttle bushings.
Just keep the cfm small since your not bulding a race truck. I'm a fan of the Edelbrock style because the Holley has a gasket seam in the middle of the float bowl.
Old May 31, 2014 | 07:51 PM
orich's Avatar
orich
Yeah old days for the Holley where leakers at one time or another.
But the Holley people got a little smarter and started making better gaskets & o-ring cups for the cross over tube.
Old Jun 1, 2014 | 12:25 AM
Marty69F250's Avatar
Marty69F250
I have a 600cfm Holley 4160 in mine and have been very pleased. Like others have said don't expect any real fuel 'economy' with these 390's, but you just gotta love the sound through headers and a good exhaust!
Old Jun 1, 2014 | 12:57 AM
Big_Tom_54's Avatar
Big_Tom_54
I had a 74 f100 2wd that I daily drove for a few years. It was very stock with a 390 c6 and I loved it. It had a 2bl on it that one of my dad's friends rebuilt and tuned for me. Ran like a raped ape. But I am torn with what to do.
Old Jun 3, 2014 | 05:14 PM
JEFFFAFA's Avatar
JEFFFAFA
The IMHO best would be a 600 Holley 4180 off 79 and newer 460 truck or econoline. Factory Ford. They have annular discharge boosters for the better fuel economy. For a 390 2V motor i'd change the jets from the factory 61's to 66-68 ish range. The factory purple secondary spring to a plain colored one. If that were to create a slight bog in Your motor then go to a brown one. If you were to put a RV cam in it then I'd keep the purple spring in it.
My second choice would be the Holley 600 noted above.
riot04
Feb 21, 2014 06:07 PM
76CamperSpecial
Jul 30, 2008 08:34 AM
hornbymatt
Mar 17, 2006 02:16 AM
8ITCOOL
Mar 16, 2004 07:07 PM
fordeverpower
Aug 19, 2003 10:42 PM
