max tire size
Old May 30, 2014 | 10:20 AM
Lost Yankee's Avatar
Lost Yankee
max tire size
Hey guys, Ive looked around on the site but cant find anything covering this, probably missed it so I appologize right off the bat, but, I need to get new tires for my 2000 xlt 4wd with a 6.8. I am running stock 265/75/16's now but would like to go up in size. My ex is stock height so what will fit with out any concerns? Thanks guys.
Old May 30, 2014 | 11:15 AM
NorthwesternCowboy's Avatar
NorthwesternCowboy
285/75/16s will fit (33"). Any bigger and there's mixed reports of rubbing/no rubbing on bumps or when turning.
Old May 30, 2014 | 12:23 PM
Lost Yankee
Thanks Cowboy, 285's are what I was looking at, dont need more ground clearance just a better foot print, thanks again
Old Jun 1, 2014 | 07:46 AM
wpnaes's Avatar
wpnaes
As I recall 305/70/16will fit a stock suspension, but the 315s need a front end level kit (and will rub a bit at full turn). The rear is fine as is up to 315/75/16.
Old Jun 1, 2014 | 10:45 AM
twtcad's Avatar
twtcad
I've been running 285's since I bought my truck in '05 w/ stock sagging suspension and I have a chunk of the inner fender well missing because the tire (all terrain) has eaten it. I'm running Toyo Open Country II.....285/75r16
Old Jun 1, 2014 | 11:20 AM
wpnaes's Avatar
wpnaes
Sorry you didn't see this solution sooner!
LT315 75R (5) Pull back the plastic inner fender with wire to keep it from rubbi... by wpnaes - Ford-Trucks
Old Jun 1, 2014 | 11:29 AM
twtcad's Avatar
twtcad
Nice....thanks.....no I never saw that, but I did try a huge zip ty and well it fell short. One day I will/may replace it, probably after I finally do my suspension upgrade that I've been wanting to do forever but everytime I get the extra cash to order parts something comes up.......
Originally Posted by wpnaes
Old Jun 1, 2014 | 11:52 AM
Lost Yankee
Ok, sounds like 285's don't fit
Old Jun 1, 2014 | 11:57 AM
twtcad's Avatar
twtcad
No they fit and look great, but you have to pull back the inner fender well as noted above or you will get a hole/rubbing sound. I just ignored it until there was a hole.......it also depends how aggressive a tread you run. Street tires = no/less issue Aggresive like I run = a hole or diy fix......either way I will never run anything smaller
Old Jun 1, 2014 | 11:58 AM
twtcad's Avatar
twtcad
I can send pics tomorrow as my wife has it in SC right now and wont be home until late tonight
Old Jul 19, 2024 | 03:40 PM
MATTHEW BAUMGARDNER's Avatar
MATTHEW BAUMGARDNER
1st Gear
Tire size for stock wheels 04 EB gasser
Hi guys and gals. Ive been reading through the threads discussed her over many years on tire sizes for stock EX's. Mine is an 04 EB gasser with stock rims. I have run stock tires for years but want something to get the truck up off the ground a bit more (without a lift kit) and have better traction all round. I see a lot of ya'll are running 285 75R 16 AND 305 70R 16 and the occasional 315 70R 16. with the front end level kit. Any one run 305 75 R 16's before. The height of this tire is 34" and the width is 12" as where stock tires are at 31.6" high and 10.4 wide. Any real world help is appreciated.
Old Jul 19, 2024 | 03:47 PM
wpnaes's Avatar
wpnaes
Yes, I ran the 305’s on stock rims, but that was after I added the front level kit. No issues in the rear. Pic is with 315’s and V/C springs from an F350.
Investments18
Dec 29, 2021 11:26 AM
Guido666
2009 - 2014 F150
Nov 30, 2015 02:56 PM
plhjb
Oct 21, 2013 07:36 PM
dave2
Nov 13, 2007 11:19 AM
chicanofire
Mar 16, 2004 08:47 PM
