Sponsored by: Real Truck
Tire Size
Old Mar 15, 2004 | 12:54 PM
chicanofire's Avatar
chicanofire
Tire Size
I just bought me a 2000 Superduty 4x4 and I was wondering if anybody knew what the largest tires I could put on the stock rims and stock suspension. I would appreciate any help. Thanks a lot
Old Mar 15, 2004 | 01:14 PM
HeavyAssault's Avatar
HeavyAssault
A tire that is about 33" will fit, you may try a 35" tire due to different suspension setups from the factory.
I think that size in metric would be a 285/75/16 or a 305/75/16 may fit.
Old Mar 15, 2004 | 01:23 PM
chicanofire
Thanks for your help Heavy Assault!!!!
Old Mar 15, 2004 | 04:26 PM
EastCoastExtremes's Avatar
EastCoastExtremes
I've got 305-70-16 on mine with out rubbing
Old Mar 15, 2004 | 11:20 PM
bender97f250's Avatar
bender97f250
285x75x16 without any issues,305's should also work,but might be pushing it for the wheels.
Old Mar 16, 2004 | 01:35 PM
truckman's Avatar
truckman
285x75x16 Dunlop Radial Rovers
Helluva lot cheaper than BFG's
http://tires2.digiknow.com/dunlop/di...ea=Light+Truck
Old Mar 16, 2004 | 02:52 PM
anfo's Avatar
anfo
285/75/16 will fit no problem. 315/75/16 on stock rims(16x7) will rub on the leafs of the passenger side, on a 16x10 the 315's will rub on the inner fender wells. If you hit some really rough road / big bumps you'll be hitting all over the place.
There is a fitment guide on natltire.com that will give you a list of the tire sizes you can use from stock - 10"s of lift. Based on my experiences above it is accurate.
Old Mar 16, 2004 | 06:32 PM
92f150I6's Avatar
92f150I6
On my truck, 305 70 R 16 (basically a 33X 12" tire) mounted on a 10" rim fits without rubbing at all. But I have the X code springs.
Old Mar 16, 2004 | 08:00 PM
SierraClubS's Avatar
SierraClubS
i just ggot 285/75/16s on my 04 f350 with stock rims and blocks in front.... i wouldnt go bigger than 295/75/16 on stock rims...
Old Mar 16, 2004 | 08:44 PM
SMiller's Avatar
SMiller
^^^^^^^^^^^^^ I thought blocks up front were a big no no?! Arn't they known for spiting out when you are going around corners? Are you aware of this? Do you know something I don't?
Old Mar 16, 2004 | 08:46 PM
SierraClubS
yeah i know well i got some blocks that are secure and wont ccome out of place
Old Mar 16, 2004 | 08:47 PM
Yeti's Avatar
Yeti
Blocks in the front are a bad idea, and illegal in some states....
