7.3 idi Alternator problems
Old May 29, 2014 | 03:43 PM
giorgio.fo's Avatar
giorgio.fo
hi everyone,
i'm having some issues with my alternator. after a cold start the battery needle goes crazy for a couple of seconds and it always takes a couple of minutes to charge my batteries completely.
It also make a squealing sound so i figured i need to change it.
My questions are:
- rebuild vs new. is it worth the cost?
- do they come with the same pigtail? with the Regulator? or i have to change the harness?
Old May 29, 2014 | 04:27 PM
Chevy_Eater's Avatar
Chevy_Eater
Sounds like your batteries are either old and not holding a charge or you have a drain somewhere.
+ your belts are loose.
So when you cold start your alternator has a heavy load in charging up the low batteries and the loose belts do not like the load.
Old May 29, 2014 | 04:40 PM
giorgio.fo's Avatar
giorgio.fo
i'v changed the belt not long ago after replacing the a/c, p/s bracket, tensioner and idler pulley. preatty sure it's the right size and it's tight enough.
how do i test my batteries?
Old May 29, 2014 | 05:17 PM
bashby's Avatar
bashby
The needle going crazy is normal for an idi, the glow plugs are still cycling off and on... They pull a lot of amperage.
Old May 29, 2014 | 05:19 PM
bashby's Avatar
bashby
It would help if we know what alternator you have, year of the truck, serpentine or v belt.
Old May 29, 2014 | 05:48 PM
madpogue's Avatar
madpogue
LOAD test. Either buy a load tester (they're cheap at Harbor Freight), or take to your FLAPS. ISOLATE the batteries first (disconnect one of the negatives). Otherwise, you'd be load testing the two together, which provides no meaningful information.
Sounds like you have a serp belt truck. If it's squealing, there's still something wrong belt-wise. Tensioner is weak, belt is too long, excessive resistance on one of the other accessory pulleys, foreign substance on one or more of the pulleys, something like that.
See if the gauge movement (is it a voltmeter or an ammeter in your year of truck?) coincides with the glow plug / WTS light.
bulldogcountry1
22
Aug 14, 2017 07:51 PM
jmhatchett
6.4L Power Stroke Diesel
Jun 11, 2015 09:28 AM
dlgerber
May 15, 2013 08:56 PM
Nyxlee
Jan 26, 2011 09:07 AM
PSDLOVER
Nov 7, 2005 09:57 PM
