truck died
Old May 13, 2013 | 10:07 PM
dlgerber's Avatar
dlgerber
truck died
Ok so my excursion died yesterday. The batteries were dead. Just had the alternator and both batteries changed a month ago. I don't think that the mechanic tightened up the belt. How do I find where the tensioner is and tighten it up my self?
Old May 13, 2013 | 10:22 PM
dlgerber's Avatar
dlgerber
Sorry it is a 6.0L
Old May 14, 2013 | 06:55 AM
tdappleman's Avatar
tdappleman
The tensioner is automatic so no adjustments are possible or required. I'd check battery and alternator connections to make sure you don't have anything loose. It's possible one of the batteries or the alternator is bad so they will need to be tested. Was the alternator a reman? Are the batteries both new and of the same type?
Old May 14, 2013 | 06:00 PM
dlgerber's Avatar
dlgerber
both the batteries and alternator are new
Old May 15, 2013 | 06:01 PM
tdappleman's Avatar
tdappleman
I'd have all three items tested as one could be bad causing the problem.
Old May 15, 2013 | 07:10 PM
Stewart_H's Avatar
Stewart_H
Have you never bought a brand new item and not have it work properly?
Yep. Also, check your body ground contacts.
Stewart
Old May 15, 2013 | 08:56 PM
X-Hibition's Avatar
X-Hibition
Are you going to have the mechanic check his own work? Brand new = warranty.
g4551
6.4L Power Stroke Diesel
Dec 19, 2016 11:43 AM
YamakidCR500
Electrical Systems/Wiring
Feb 11, 2011 09:09 PM
jls8177
Sep 4, 2009 07:05 PM
swaybar
Dec 26, 2008 08:22 PM
Inksma
Dec 14, 2006 04:18 PM
