Error codes suspension?
Old May 26, 2014 | 12:39 PM
omegalita's Avatar
omegalita
Swissnavigator
Hi
Can somebody say me, what these codes mean? (I have the "check suspension light coming on after 10 Minutes).
C08<D
B2TAE
ROR
P092B
DAT
B2ERR
C03<D
B04<D
Thank you!
Old May 26, 2014 | 06:22 PM
projectSHO89's Avatar
projectSHO89
What vehicle are you working on?
Where did you get those 'codes"?
Old May 27, 2014 | 01:49 AM
omegalita's Avatar
omegalita
Swissnavigator
i work on the 98 Navigator.
The codes are comming from an Android-Tool... i know, i have to check with another OBD software...
The suspension seems to work well, only the dash-light will come on after about 10-15 minutes driving...
i found that error P092B: "Gear shift lock selenoid/Actuator control circuit "B" range"
We want to go on holiday at the weekend ... Does it have an impact on the air suspension?
Old May 27, 2014 | 06:36 AM
projectSHO89
I've never seen that code on any Ford. Besides, the Ford gear shift lock doesn't have any sort of feedback or connection into the rest of the computer system so there is no way to ever get a fault code for that component.
I'd have to conclude that the codes you pulled were junk and are not useful.
Old May 27, 2014 | 09:45 AM
omegalita's Avatar
omegalita
Swissnavigator
OK.
This evening i go to a Ford dealer. He should read the codes or see what kind of faults there are... Hope so...
Old May 27, 2014 | 09:52 AM
2trux's Avatar
2trux
If your compressor is cycling a lot (slow leak) this would cause the light to come on. I have this happen when I am 4 wheelin. Turning the truck off/on resets it and it's good to go for a while. When the light comes on the compressor stops working which could cause your suspension to go down if there is a leak.
Old May 27, 2014 | 10:57 AM
omegalita's Avatar
omegalita
Swissnavigator
So... error code is C1725..
Now i have to search for the fault...
Everything else is working fine, compressor runs normal... Only the front shocks won't deflate as i see...
will provide you with more info after my search...
Old May 27, 2014 | 11:51 AM
projectSHO89
A c1725 indicates there is a problem with the front air shocks.
Possibilities include the ride height sensors, the solenoid valves for filling or venting, or the electronics controller for the air ride system.
The factory service manual has the diagnostic procedure for the fault code but it does not appear to be something that can be done without the proper test equipment and procedures.
Old May 28, 2014 | 12:35 AM
omegalita's Avatar
omegalita
Swissnavigator
As far as I can see, all works.
If I press along the sensor, it also pumps up, then he bled again as it should.
But after 10 minutes is the "check suspension" again ...
Strange, because with this setting, I drive already almost 4 years without any problems
Old Jul 6, 2014 | 10:09 AM
omegalita's Avatar
omegalita
Swissnavigator
The problem was: torsion bars were to high.
Lowered them and the problem was gone... :-)
kbf1961
Oct 17, 2015 10:05 PM
ldunston7621
Apr 24, 2015 01:42 PM
Craze
Jul 12, 2004 02:06 PM
strokeman
Aug 27, 2003 10:36 AM
