NEXT INTERIOR MAKE OVER
Old May 15, 2015 | 08:58 AM
  #136
MIKES 68 F100's Avatar
MIKES 68 F100
Thanks !
the Air /fuel gauge was the odd ball gauge so didn't want to squeeze it in the custom cluster . I think i'll just recover the pod with same material , taking my time this time .
Old May 15, 2015 | 09:08 AM
  #137
emeraldcoupe's Avatar
emeraldcoupe
really nice build! that rear view mirror looks real close to the mirror in my '66 mustang.
Old May 15, 2015 | 09:53 AM
  #138
orich's Avatar
orich
Yeah right, I've seen one on ebay before but don't know if it mounts flush up like this 67 trucks do.
The chrome shop did a really nice job of rounded off all the sharp casting points before plating it.
I saw a 1967 on ebay not long a ago nos one that had a dent in it like from what looks like from being dropped with the attached mirror bruising the soft metal where the mirror would fold upward making contact with bracket arm. It went for like $78 bucks with S&H.
I figured hell, I could just get mine chromed for what it went for and did.
Orich
Old May 15, 2015 | 05:02 PM
  #139
bajafishnut's Avatar
bajafishnut
Nice work Mike, I like it all, and the smiths gauges are just the right touch. Had an old BSA in the mid 60's with Smith's.. Love that look. Its the attention to details, that makes your truck unique, and personal. Pride in ownership, is personal, and we all empathize with the effort. Kudos to you bro.
Baja
Old Oct 31, 2016 | 02:09 PM
  #140
MojaveMuse's Avatar
MojaveMuse
I like what you did, and the gauge up on the pillar instead of zip tied/ hose clamped onto the column
Old Oct 31, 2016 | 02:18 PM
  #141
MIKES 68 F100
Thanks ! after doing all the paint work I just couldn't hose clamp it to column .
Old Nov 1, 2016 | 02:51 AM
  #142
GaryKip's Avatar
GaryKip
What a super idea. It's out of the way and blends in very nice!!
Old Nov 1, 2016 | 12:23 PM
  #143
bajafishnut
Does anybody make an after market pillar gauge holder for our old Bumps? That is a great idea amigo, and very nice fab job.. I am wondering if I could use PVC pipe and fiberglass over it, if the resin would not eat the PVC.?? I am thinking that a 45 degree street L, and cutting half or 2/3 off the main part so it would fit with the pillar?? Comments?? most welcome.. humor too..
Baja
Old Nov 1, 2016 | 12:42 PM
  #144
JEFFFAFA's Avatar
JEFFFAFA
Stumbled across this. Would work if someone was already making their own headliner.
Or this if the dash pad is removed and holes filled. Including the speaker holes.
Old Nov 1, 2016 | 12:49 PM
  #145
MIKES 68 F100
I searched long and hard for a Pillar pod for our trucks , No one makes them .
I thought about the PVC route but figured it might end up to square and thick . So bought the 94 f150 pod and used it for the general shape . It was only like $20 if I remember right .
Old Nov 1, 2016 | 12:52 PM
  #146
orich's Avatar
orich
Russ, I came across a 80's pickup that had a 3 gauge pillar post setup at my loco pick n pull.
I pulled it out and tried the fitness into a dent pillar post.
It was about an 3/4" to 1 inch too wide but with some trimming it may have fit real good.
I almost bought it but thought hell, I don't want to make it a magnet for some A-Hole to
want it more then me bust my window and attempt yank it out.
Kind of like those big 5" tachs some guys hang up or on the dash there.
But it look like an easy fix to make it work or a good base to start with it was gray looking PVC which pretty ez to fab an glue together.
I almost when with the 3 pod on dash mount setup until, just buying a new dash pad.
So that was out.
Orich
Old Nov 1, 2016 | 02:00 PM
  #147
bajafishnut
In re-thinking this, I believe that a PVC fitting may be too thick, as commented on by Mike, and in looking at the pillar angle, on our Bumps, it appears to be too vertical to use a PVC 'street L' or the 45 deg angle fitting... well, nothing is easy, if it was, anybody could do it.
Baja
Old Nov 1, 2016 | 07:51 PM
  #148
HIO Silver's Avatar
HIO Silver
Exhaust tubing and welded into a wireframe.. polyester fleece stretched over and then resin applied to harden. Apply filler and sand, sand, sand. Prime, paint, assemble, and mount.
Old Nov 27, 2016 | 07:04 PM
  #149
mrpotatohead's Avatar
mrpotatohead
Carpet
What type of carpet is that from Stock interiors? They offer several different kinds and I like the look of yours.
Old Nov 28, 2016 | 09:37 AM
  #150
MIKES 68 F100
I think it was 80/20 loop dark saddle . Been Awhile
You can request Free samples , I got like 12 different samples and compared to my oatmeal tweed fabric and paint .
