Hi.. I need a new signal switch with wiring and the bezel where the shifter goes int the colum is also broken out at the pin hole .will parts from later models work? thanks for any help.
maslo
You should be able to get a turn signal repair kit at NAPA or other good parts house. The shift collar is the same from '68 - '72, Mac's has them new: http://www.macsautoparts.com/
