ignition swap
Old May 23, 2014 | 10:33 AM
zombievan1966's Avatar
zombievan1966
ignition swap
my van had a pertronix flamethrower ignition and super coil. it was damaged so im converting back to points and condenser. can i use my super coil ? I was told to install a ballist resistor. can someone explain what the ballist resistor is and if i realyl need it in my 66 falcon super van? my motor is a 240 l6 btw.
Old May 23, 2014 | 03:52 PM
tjc transport's Avatar
tjc transport
i ain't rite
the ballast resister cuts coil voltage down to between 6 and 8 volts for prolonged points life. if you put straight 12 volts to the points they will work, but need to be changed more often.
Old May 23, 2014 | 04:49 PM
Tedster9's Avatar
Tedster9
Check the voltage at the coil now - with engine running - and you may find you are already running a ballast resistor. The way it worked back then when the key is turned to start, full battery juice goes to the coil for a fatter spark to aid in cold weather. When the key is in run position the voltage is dropped to ~7 volts continuous. Aftermarket high output coils need the full 12+ volts to take advantage of wider plug gaps and work their best.
MARC
Dec 4, 2016 09:08 AM
Rmc292
Oct 17, 2013 06:24 PM
ranch67
21
Jan 29, 2013 09:19 PM
Brad Brown
Electrical Systems/Wiring
Jan 4, 2012 11:36 PM
DT 466Man
Jan 29, 2007 05:55 PM
