How do you stop engine from rotating when torqueing Bolts.
Old May 22, 2014 | 01:46 PM
SaturnSky11's Avatar
SaturnSky11
Have a 2001 Ford ranger 3.0L with an Auto transmission that I’m currently work on replacing the timing chain cover gasket. Looking ahead The question I have is when re-installing the Harmonic Balancer (using a HB installer tool) then torqueing down its bolt as well as re-installing the crankshaft pulley what is the best way to prevent the engine from rotating? Engine is in the vehicle.
Thanks for any input to this question.
Old May 22, 2014 | 07:46 PM
Rockledge's Avatar
Rockledge
How about a strap wrench?
Old May 22, 2014 | 08:24 PM
SaturnSky11
I think that might work for the pulley & maybe the harmonic balancer bolt. But what would you put on when pressing on the harmonic balancer?
Old May 22, 2014 | 09:37 PM
Tedster9's Avatar
Tedster9
Always put it in gear w/ a manual. Or some wedge a block of wood in the flywheel, neither of will work with an AT? Not sure on that. Have changed them in an automatic, remember the problem, can't remember the remedy. (Helpful ain't I?)
Another method is to introduce a good length of rope into a cylinder so it locks up the motor that way. That one never appealed to me enough to try it, for sure.
Old May 22, 2014 | 10:43 PM
Old93junk's Avatar
Old93junk
Use a air impact gun.........problem is no longer a problem.
Old May 22, 2014 | 10:56 PM
mfp4073's Avatar
mfp4073
access plate on the back of the "bellhousing". Wedge a screwdriver in the teeth. Takes 2 people, but its doable with reg tools.
Old May 23, 2014 | 04:22 AM
SaturnSky11
Don't have one.
Old May 23, 2014 | 04:26 AM
SaturnSky11
Could you explain this method some more?
Old May 23, 2014 | 09:10 AM
tomw's Avatar
tomw
If you wedge the screwdriver, it may get jammed and then you'll be turning the crank bolt backwards to un-jam the tool.
I believe the safest method is to pick an easily accessible spark plug, remove it, and feed in a couple feet of rope. Rotate the crankshaft by hand {ratchet wrench} in the counterclockwise direction until the rope jams the piston and prevents it from turning.
Make sure to leave some rope hanging out the plug hole or you'll be fishing...
To install, you'll have to un-jam the rope, or just turn the crankshaft in the opposite direction until it jams again.
I would not use an impact wrench unless it had an accurate way to measure the torque. A broken bolt due to over-tightening is a big price to pay if you use an impact.
tom
Old May 23, 2014 | 09:56 PM
mfp4073's Avatar
mfp4073
edit, wrong thread!
Old May 24, 2014 | 07:45 AM
SaturnSky11
Why would I rotate the crankshaft counterclockwise? When I go to install the Balancer & torque the bolts the Crankshaft will rotate Clockwise with the Bolt. Undoing the CCW jam. It should eventually jam going the other way. My concern with this method is about damaging a valve. How would I make sure I'm on the compression stroke?
Old May 24, 2014 | 08:20 AM
tomw's Avatar
tomw
CCW to remove. CW to install. You do the math. One would 'think' you had to REMOVE it before you could then INSTALL it.
If you just rotate CW after R&R the balancer, the piston will go down on the power stroke, will come up on the exhaust with the valve open,etc. To avoid, unjam the rope & remove it. Rotate the crankshaft CCW so it is on compression, feed in rope, rotate CW.
To avoid th valve potential problem, think about where you are in the combustion process, and always jam the rope immediately BEFORE tdc to tighten, and AFTER TDC to remove. It take a bit more, but you will be sure the valves are closed.
tom
Remember: Righty Tighty, Lefty Loosey
Old May 24, 2014 | 09:17 AM
SaturnSky11
Thanks for helping tomw. I'm a novice to some extent. Done a lot of work on my vehicles just not in this area. I have the balancer off. Used a breaker bar up against the frame & turned the engine over to get the bolt off. This thread was started with the intent to re-install the balancer & pulley which is where I'm at now.
Please clarify your term "R&R the Balancer" (Remove & replace?) I'm figuring your referring to piston #1. So once at TDC I'll rotate CCW to lower piston back down the compression stroke. Insert the rope. About 2 feet OK? Then rotate the crank CW back up the compression stroke till it can't rotate anymore. Then finish installing the balancer & torque its bolt. Then install the Pulley & torque the 4 bolts. Once this is done then rotate crank back CCW to remove rope. Does this make it seem I have the step correct?
Old May 24, 2014 | 12:04 PM
tomw's Avatar
tomw
In a word, yes. You nailed it. Good luck.
tom
Old May 25, 2014 | 01:19 PM
SaturnSky11
With the use of a Harmonic Balancer installer & the rope inserted into cylinder #1. I was able to get the Balancer & the Pulley installed back on. I used about 6-7 feet of 1/4 inch rope. Thanks of everyone who helped.
jerryst
Jul 12, 2018 02:19 PM
Encho
Mar 2, 2010 10:50 PM
muddyford911
Jun 17, 2009 08:36 PM
FFOORRDD96
Dec 28, 2004 11:46 PM
ExcellentRed
Aug 1, 2004 04:52 AM
