351 odd choking?
Old May 27, 2014 | 08:19 PM
Mioxy83's Avatar
Mioxy83
351 odd choking?
1993 f250 247,450 miles 351 decides it wants to choke... like its realbad when going from reverse to drive and giving it gas cause it HAS died before. Someone said fuel pressure regulator might be a little ****ty idk And it does it at stops too. I do have a CEL but it comes back for things like MLPS and O2 sensor I mean I didnt really think an o2 would so this. All filters are new. Plugs. Rotor. Cap. Ignition coil. Battery. Also once I replaced my belt I acquired this weird whistle? Like maybe I over tightened it but its more prominent when you givenit gas too like a wind blowing from a small hole. Not like a vac leak hiss
Old May 27, 2014 | 08:32 PM
Conanski's Avatar
Conanski
You need to measure fuel pressure, but also post up exactly what codes you're getting.. on these trucks the codes generally just point you in a direction they don't tell you exactly what is wrong.
Old May 27, 2014 | 08:36 PM
Mioxy83's Avatar
Mioxy83
I get a 617 trans shift fail 1+2
628 excess converter slippage
634 park or nuetral circuit failure
172 o2 sensor
332 egr valve
bucks150
May 26, 2020 09:52 PM
BCHauler
May 13, 2008 12:20 PM
marragtop
Jul 25, 2005 10:30 AM
KYHossF150
Apr 18, 2005 09:13 PM
Rotor
17
Apr 15, 2005 11:12 PM
