flywheel problem
Old Oct 16, 2000 | 05:26 PM
ent's Avatar
ent
flywheel problem
Old Oct 22, 2000 | 01:44 PM
1985f150freak's Avatar
1985f150freak
flywheel problem
I have a 1985 ford f-150 with a 3speed with overdrive. I have recently took the cluth pressure plate and throwout bearing,to find out the flywheel was realy cooked and cracked beyond repair,I got another flywheel but it was not the same bolt pattern, so i ask someone and was told it was for a 11 inch clutch, I had a 10 inch clutch,So i decided to change to a 11 inch,I purched at my local napa store,The pressure plate bolts do not line up ooops,Any ideas???Maybe the wrong flywheel...
Old Oct 22, 2000 | 05:55 PM
billyb's Avatar
billyb
flywheel problem
take back the 11" flywheel and get the correct one. be aware that the 11" will have more pedal pressure.
my 85 has a flywheel that has both patterns on it.
also be careful to get proper year flywheel as 80 and earlier were balanced differently.
Old Oct 23, 2000 | 04:15 AM
1985f150freak
flywheel problem
thank you for the info,I had the right one and i got another flywheel,i guess it must be wrong the hole didnt line up...Thanks again
