1965 AUTO SHIFT INDICATOR
Old May 20, 2014 | 05:12 PM
orentzroy's Avatar
orentzroy
I AM HAVING PROBLEMS IDENTIFING AND LOCATING PARTS FOR THE GEAR INDICATOR ON MY STEERING COLUMN, THE STAMPING # ON THE COLUMN FLANGE IS C5DA .I CANNOT LOCATE THE POINTER(PLASTIC) OR THE INDICATOR.
Old May 21, 2014 | 03:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by orentzroy
I AM HAVING PROBLEMS IDENTIFING AND LOCATING PARTS FOR THE GEAR INDICATOR ON MY STEERING COLUMN.
THE STAMPING # ON THE COLUMN FLANGE IS C5DA. I CANNOT LOCATE THE POINTER (PLASTIC) OR THE INDICATOR.
The original A/T shift collar had the pointer made as part of it. In 1973, Ford replaced the original collar with another. This collar has a separate plastic pointer that slips into a slot on the collar.
The pointer was available by itself, it also comes with the collar. The pointer itself is now obsolete, the collar is still available from Ford.
D3TZ-7A110-A .. Plastic Shift Dial Pointer / Obsolete
BAYER FORD in Comanche TX has 2 = 325-356-3777.
XIT FORD in Dalhart TX has 3 = 806-244-8511.
PARTS INTERNATIONAL in Farmers Branch TX has 3 = 888-727-0418.
NOS PARTS LTD in Waxahachie TX has 14 = 972-037-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 882 = 800-476-8653.
C5TZ-7B033-A .. Shift Indicator Dial - The original 1965/66 A/T shift dial: P R N o O L (two green dots between N & L). It's obsolete, no one has any NOS and it's not reproduced.
C7TZ-7B033-E .. 1967/72 A/T shift dial: P R N D 2 1 can be substituted, it's also obsolete, but has been reproduced by Carpenter. Genuine Ford: NOS PARTS LTD has 1.
Old May 21, 2014 | 08:25 AM
orentzroy's Avatar
orentzroy
THANKS
THANKS FOR THE CLARIFICATION , I AM CURIOUS AS TO WHY FORD MAINTAINED THE C5 YEAR STAMP ON THE COLLAR.
ANYONE HERE ON THE FORUM HAVE ANY OF THESE OFF A USED COLUMN?
Old May 21, 2014 | 08:43 AM
NumberDummy
There is no C5 or any other number marked on the shift collar. The upper flange has an ID engineering number cast on it.
C5DZ-3511-B .. Upper Flange-Use with A/T / Marked: C5DA-3511-BP / Obsolete
Applications: 1965/66 F100/250 - 1967/72 F100/350.
Old May 21, 2014 | 11:02 AM
orentzroy's Avatar
orentzroy
FLANGE
YESSIR , I MEANT FLANGE , IT IS MARKED C5DA , THANKS FOR THE ASSISTANCE. ROY , http://i1168.photobucket.com/albums/...pseed2734a.jpg
The Masked Rider
Oct 27, 2020 07:56 AM
tvliftcabinet
28
Apr 12, 2017 05:48 PM
rande bly
Jul 5, 2012 03:41 PM
tommyatric
Oct 19, 2011 11:46 AM
WayneBurton
37
Dec 27, 2009 02:00 AM
