3 speed toploader id
Old Jul 7, 2003 | 01:35 AM
boss460's Avatar
boss460
Exclamation 3 speed toploader id
i have a 3 speed toploader
main case
C8AR
7006 B
ID TAG
RAN BB 1
02672 5 (S)
INPUT SHAFT HOUSING
C5AR
7050 B
TAIL
C87R 7A040A
this is going in my 93 mustang behind my 460 will it hold up? this is not a race just a show car daily driver?
THANKS for all the help
Old Jul 7, 2003 | 01:42 PM
steve83's Avatar
steve83
This is a truck BBS, so you probably won't get much on a car transmission here. Have you tried the Mustang BBSs?
Old Jul 7, 2003 | 02:37 PM
boss460's Avatar
boss460
dose it matter besides im puting it on all the board im a member it might be a truck tranny anyway
Old Jul 7, 2003 | 07:47 PM
Mike W's Avatar
Mike W
It's a truck and a car transmission. Didn't find any info on the tag. A 72 manual (truck) shows three different gear ratios:
170 1v 3.41 1.86 3.87(rev)
240, 300, 302, 360
2.99 1.75 3.17(rev)
390 2.42 1.61 2.57(rev)
It is known as the Ford 3.03. I don't know how it compares to the 4 speed toploader for strenght. I think the 4 speed may be stronger.
Old Jul 7, 2003 | 11:37 PM
alpo23's Avatar
alpo23
Strength is = to the 4-speed. As long as the teeth are in good shape the only other thing is listen to the countershaft bearings when in 1st or 2nd gear. If quiet, then it is in good shape. the counter shaft bearings do go out over time ( 200,000+ miles). This tranny is fine for what you want to do.
Eric
Old Jul 8, 2003 | 01:01 PM
boss460's Avatar
boss460
thanks for all the help and info the best help has come from this site so far. tell me if im right on this one. from the decode the main case looks to be a 68 Galaxie and the tail 68 mustang the good number on the tail is C8ZR. so my question is. is this right or do u think this is a rebuilt tranny some time in its life
Old Jul 8, 2003 | 07:40 PM
Mike W's Avatar
Mike W
I don't know about the numbers. The 4 speeds had different tail housings for shifter mounting in different cars. I am not aware of the 3 speed having this characteristic.
Old Jul 8, 2003 | 08:13 PM
Polkat's Avatar
Polkat
Don't worry about the different numbers. These trannys were assembled from the parts that were current at the time. A part designed...lets say in 1968 (C8xx) would stay in use with that number until a design change was created, sometimes for years.
Your numbers indicate parts from '65 and '68, and some of these three speed parts were used well into the '70's.
Could it have been rebuilt? Sure, but it's highly likely that only internal parts were changed, unless case parts sustained some kind of damage, and even then they were probably replaced with similar casting numbers. I wouldn't put one of these into a resto show car, as I doubt the 460 ever came with a 3.03 (or a 460 in a '93 Mustang for that matter) but it is one tough tranny.
Check out the syncros as well.
PRUSue
Aug 31, 2016 11:34 PM
dlb.motorman
Oct 5, 2015 05:50 AM
401477534
Mar 10, 2011 09:39 PM
STGFordCrazy04
Feb 20, 2008 11:49 AM
286merc
Apr 3, 2003 08:27 AM
