Mating BBF FE to a toploader?
Old Aug 31, 2016 | 11:09 PM
PRUSue's Avatar
PRUSue
Hi, I have 428 FE with a bellhousing coded C5TA7505B, which is a truck bellhousing I believe. The transmission I have is a small block 4 speed toploader. Is there a problem mating these two parts?
I know this has been covered in other places, but without an illustration I don't really understand the issue. I keep reading the truck bell is deeper than the car bell, and the BB toploader is shorter than the smallblock toploader. At the end of the day, when you bolt it all together- how can you tell if you have a problem?
Old Aug 31, 2016 | 11:34 PM
85e150's Avatar
85e150
This guy cautions against the truck bell:
Bellhousing ID Chart
I thought the SB had a longer input than the BB model.
IMO, if you can bolt it up and it has sufficient engagement at the pilot, and the clutch disk splines allow the disk to properly align with the pressure plate, you should be OK.
Mock it up without the block plate and flywheel. Use washers or shims to hold the bell out the same distance as the block plate. Without the flywheel, you will be able to see the pilot-input shaft marriage and determine if it will last or if it's doomed.
Or, buy a high dollar Quick Time bell, or search for a stocker.
Jim_1
Feb 7, 2023 07:27 PM
tony paul
Dec 23, 2014 11:13 AM
johncart
Feb 18, 2008 08:39 PM
Alz Ryde
Jan 16, 2006 02:25 PM
67ranchero
Aug 12, 2004 07:26 PM
