300 inline six carbed emissions motor picture
Old May 24, 2014 | 07:49 AM
  #31
bill06447's Avatar
bill06447
Originally Posted by raven3
Have found two different configurations using the smog/air pump on pre EFI.
1. Manifold rail with air injector fittings , 1/2" x 20 tapped holes in head
discharge of smog pump is connected to manifold through a check
valve. Hole in EGR adapter plate used for configuration #2 is plugged.
2. All six air injection holes in head are plugged with allen head screws.
discharge from smog pump is connected to side of EGR adpater plate
through a check valve.
Both configuration incorporate the curved heat tube from the exhuast manifold to ERG adapter plate
Then there must be a third...the AIR pump on my 86 injects the air through a one inch pipe with a check valve into the exhaust just ahead of the first cat. Another pipe with check valve goes into the EGR adapter plate. ~Bill
Old May 25, 2014 | 05:49 AM
  #32
raven3's Avatar
raven3
The F150 that has #1 configuration is a Dec 1981 build date sticker in the door.
The F150 that has the #2 smog pump configuration is a later year build date , pre EFI with carburetor, with the exhaust missing from the stock cast exhaust manifold to the front of a round muffler.
Old Jun 2, 2014 | 11:11 AM
  #33
MarkinTexas's Avatar
MarkinTexas
Originally Posted by redroad
Here is a picture of a 300 carbed emissions motor if someone needs it for reference .. Hard to find one this complete
Hi all –new here – just “picked-up” a ’74 F100 with a 240 I6. It runs but not great – seems tohave either ignition and/or carb issues.
The 1-bbl carb looks like (very similar) to the onepictured. My question is – what is the small solenoid? on the back, passenger side of the carb. It has a rubber boot, and a wire. The (black) wire on mine is just cut. There is a rod going through it,and is seems it should contact a rod/lever back on the carb. Thanks for any input!
Old Jun 2, 2014 | 02:56 PM
  #34
redroad's Avatar
redroad
Take a picture and post it so there is no misunderstanding
Old Jun 7, 2014 | 02:28 PM
  #35
oneowner83's Avatar
oneowner83
The back passenger side sounds like the A/C solenoid.....it kicks up the rpm's when A/C is on.
Old Jun 8, 2014 | 07:46 PM
  #36
bill06447's Avatar
bill06447
The solenoid is used on the trucks even without ac. Set the idle speed with the solenoid energized, when you shut off the engine the solenoid de-energizes letting the throttle close completely preventing "run-on". ~Bill
cmdk_93
Dec 26, 2012 09:58 PM
jaymaechtlen
Feb 16, 2012 10:49 AM
Swampy78
Jul 8, 2011 09:24 AM
fourpointnine
Jun 3, 2011 11:46 AM
ROTCJS
Mar 9, 2003 12:19 AM
