batteries shorted out??????
Old May 17, 2014 | 12:08 PM
trevorrules's Avatar
trevorrules
my 1995 f250 powerstroke has had something short out when I hooked up a new radio...so I took it out and now my batteries are fried....so I put a ohms meter on it and the passenger side battery reads open then on the driver side battery it reads closed ..... I need to know if this is normal anyone?????????????
Old May 17, 2014 | 12:51 PM
rla2005's Avatar
rla2005
You cannot measure a battery's resistance with a DVM, only the voltage. If you put the meter leads in the amp slot then you can measure the current draw out of the battery.
Old May 17, 2014 | 01:47 PM
trevorrules
sorry I meant the battery clamps that I was measuring ohms would you still know anything about that
Old May 17, 2014 | 05:51 PM
rla2005's Avatar
rla2005
What are you using as a reference? I am not following your methodology.
Old Jun 7, 2014 | 12:49 PM
trevorrules
never mind I found what the problem was ...I had the door open and the switch in the door closed causing the ohms meter to sound consistently
Old Jun 7, 2014 | 12:52 PM
rla2005's Avatar
rla2005
Glad you found it
DevilDocTater
Jul 10, 2012 11:49 PM
jmm
Electrical Systems/Wiring
Oct 1, 2011 08:14 PM
RickF350
Nov 25, 2007 06:06 PM
dannacc
Garage & Workshop
Feb 28, 2005 04:29 PM
Aekisu
Dec 2, 2003 11:51 AM
