I've never had a vehicle with two batteries before so i'm not sure of the proper charging procedure.
So How do I go about charging the batteries in my truck with one charger? At what amp (40,20 or 2) should I set the charger? Do I charge them one at a time or both at the same time? If charged at the same time, which battery gets the + lead and/or which battery gets the - lead?
When charging a battery, disconnect both leads from each battery and charge them seperately for best results.
