Leveling kit problems
Old May 17, 2014 | 08:30 AM
DavidSmealII's Avatar
DavidSmealII
Just bought the procomp 2.5 leveling kit, new upper control arms (Moog) and two oem struts for my 2004 fx4.
It looks great on it and everything but I'm having the same clunking noise before I tore into it and it's driving me insane.
I know the control arms are rubbing on the coil spring and that's what I think the noise is but then that wouldn't make sense since the noise was before hand but I think it only made it last time due to the coil spring being broke in half. I just need some help please!!
Old May 17, 2014 | 11:35 AM
danorules's Avatar
danorules
Did you check the sway bar link
Old May 17, 2014 | 09:41 PM
cb_13's Avatar
cb_13
I agree with Dano check the sway bar links. I have also heard ball joints and outer tie rod ends clunk if they were loose enough.
Old May 21, 2014 | 03:52 PM
DavidSmealII
Yeah I took the sway bar links loose to lower the control so the strut could slide out...worse comes to worse ill just get new sway bar links and see what happens...
Old May 23, 2014 | 06:59 PM
DavidSmealII
I know for a fact it's not the sway bar links. My strut spring is having paint rubbed off from the control. I don't know how to fix this cause you can't put anything on backwards when it lines up only one way.
daveya48187
Escape & Escape Hybrid
Apr 7, 2011 09:47 PM
spatts
2004 - 2008 F150
Jun 27, 2008 06:33 PM
riley42204
Nov 9, 2005 06:16 AM
Cobratodd
Aug 28, 2005 05:04 PM
ep
Jan 27, 2002 10:04 PM
