Leveling Kit Help
Old Nov 9, 2005 | 05:34 AM
riley42204's Avatar
riley42204
Leveling Kit Help
Hey guys I just installed a 2.5" leveling kit on my 02 250 4x4 sc lb and have a problem with the drivers sway bar bracket grinding on the new leaf springs. Is there any way to fix this problem. When I hit a bump the grinding sound is very loud, and the leaf spring is grinding away at the sway bar bracket.
Old Nov 9, 2005 | 06:16 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
you mean the actual sway bar is hitting the leaves? or the link that connects the frame to the sway bar? have you checked to make sure the link is on the correct side of the sway bar?
