Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Broken carb stud in intake
Old Aug 19, 2003 | 09:39 PM
willowbilly3's Avatar
willowbilly3
What holds them in?
Old Aug 23, 2003 | 10:17 PM
monckywrench's Avatar
monckywrench
After the insert is installed in an appropriately tapped hole, small "keys" are driven in to lock the insert so it cannot rotate. The link above has links to instructions and photos.
Old Sep 17, 2003 | 05:25 PM
Mark C. Richardson's Avatar
Mark C. Richardson
Got a broken stud, Heres a tip. I use to remove many broken screws from avionics boxes in the navy. We would use a dremel tool with carbide dental burrs. They come is different sizes. They work great. However comma, You need to use some kind of coolant and let the cutter work don't force it. you can play with the rpm, what ever work best just try and not let it get to hot, Or you will be digging out carbide. Try MSC for a supplier if no luck you can email me thru the system email.
-note: System email should work for established users even tho it is restricted for new users to prevent spam, -Admin.
PS Check out my 1962 Unibody under classic trucks, Rich's 1961
PS Once you get through the middle use a regular drill, take your time
Old Sep 22, 2003 | 10:23 AM
Krump's brother's Avatar
Krump's brother
Don't know how to make it "clicky" but Kroil can be found at
kanolabs.com
Silikroil is by far the best stuff I have used.
VTENX
Oct 10, 2020 04:56 PM
Brentmez45
2009 - 2014 F150
Nov 5, 2016 05:02 PM
Mr. Obvious
Modular V10 (6.8l)
Mar 31, 2016 10:06 AM
300sflyer
Modular V10 (6.8l)
15
Mar 15, 2016 01:31 AM
Super Wagon
Mar 10, 2013 12:08 AM
